Pearl - PH-44 ( Phaser ) [schematic]
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
http://www5b.biglobe.ne.jp/~houshu/synth/Ph44core.gif
Does enyone have something more on this???
please
please
- Bernardduur
- Transistor Tuner
I have one now open and tracing........ man, big pedal with a lot of connections
- The Rotagilla
I've only got the schematic for the PH-03, sorry.
- borislavgajic
- Opamp Operator
some guts ??? ...................thanksI have one now open and tracing.....
- kierc
- my favorite amplifier: Vox Cambridge 30 R Twin
- Completed builds: Clyde McCoy Wah with Whipple+Red Fasel inductor switch, Fuzz Face with own layout
- Contact:
There's one on eBay right now (couple of hours left though! @ £49 atm)
http://cgi.ebay.co.uk/RARE-80s-Pearl-Ph ... dZViewItem
Just thought I'd post it!
- Bernardduur
- Transistor Tuner
Schematic (put in parts as it is a HUGE one )
PSU
Audio path
Phase stages
Parameters
Switching
The huge thing on the right on the parameters schematic is a MC14007 IC with the pinnumbers..... didn't have on in my software. Everything in this unit is fed with the V+2 (12V) but the LEDs are fed with V+1 (18V). Speed ramps up and down when the speed button is pressed.
Part marked "switch" in "Switching" schematic connects to "Sw" in "Audio path" schematic
PSU
Audio path
Phase stages
Parameters
Switching
- The Rotagilla
Awesome, thank you!
- borislavgajic
- Opamp Operator
thanks...... it is big!!!
- unbeliever
Thanks.
- Dirk_Hendrik
Bernard,
Excellent work! Those buggers are bitches to trace.
- borislavgajic
- Opamp Operator
can somebody please repost those images and schemes???
thanks
boris
thanks
boris
- Bernardduur
- Transistor Tuner
- mictester
Excellent!
Now that's a different way of doing a phase stage! If you select the transistors (or use an array on an IC), you can eliminate differences between stages. I'm going to have a play with that way of doing things. Thanks for posting your tracing!
- borislavgajic
- Opamp Operator
- Bernardduur
- Transistor Tuner
- Bernardduur
- Transistor Tuner
- modman
- a d m i n
- Has thanked: 4394 times
- Been thanked: 2131 times
