MXR - 6 and 10 band Equalizer  [schematic]
george giblet
Has thanked: 206 times
Been thanked: 309 times
Post by george giblet »
I've been sorting through some of my stuff over the holidays and you might be interested in these:
MXR 6-band EQ:
MXR 10-band EQ:
Here's the location of the missing parts which can be updated from any new gut shots:
thanks george!
fosnal1950
Post by fosnal1950 »
Is there anyone who knows if there is a pcb available for the 6 or 10 band ?
I'm not very good at designing it for so many opamps.
Alf
Has thanked: 232 times
Been thanked: 887 times
As said before, thanks George.
Make those tapers linear. It's a linear cut boost app ;) (A "w" taper like in the TS tone control would be even nicer...)
fosnal1950
I have found a pcb and layout for the GE-7 but it's in pdf.
I can't show it here. Tried to convert it to jpg but all these so called free programmes add letters behind the converted file.
If anyone needs it mail me .
Alf
fosnal1950
Here you go : the site where I discovered it .
http://web.tiscali.it/boxsmt2clone2005/ ... ss_ge7.htm
Alf
lolbou
Has thanked: 308 times
Been thanked: 225 times
Post by lolbou »
Hey,
I've been through this site already, but could not find the very linear faders that fit the PCB... Course I can modify them with an appropriate software, but does anyone know where to find these Boss style ones?
A bit off-topic maybe? Sorry about that... :|
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
nzino
Post by nzino »
Hi
I need schematics of MXR 6 band EQ with footswitch (the latest one, black colured) to repair. Some one can help me??
Thanks.
mecmast
Post by mecmast »
any layout/pcbs plz?
Rocket Roll
Has thanked: 19 times
Been thanked: 44 times
Post by Rocket Roll »
MXR 10-band EQ master volume mod:
shotgunn
Post by shotgunn »
Better late than never... I just found this site. I have the PCB layout for the MXR-109.
mcraveri
Post by mcraveri »
Hallo,
Does anyone have a layout with tracks?
Tanks
Lonkero
my favorite amplifier: Tech 21 trademark 10
Post by Lonkero »
Why some freq gain stages use 1458 and some that TL op-amp?
HTH
Post by HTH »
Lonkero wrote:Why some freq gain stages use 1458 and some that TL op-amp?
noise specs?
O.B.Y
my favorite amplifier: marshall jcm 900
Completed builds: - rebote 2.5
- fuzz face.. fuzz factory with 2n404 transistor's
- electric misstress flanger
- balck cat hot cat
- big joam
- tremulus lune
and many more..
because im still learn more for it..
Post by O.B.Y »
does it verified?
No.
factory schems never do it verified.
O.B.Y
- balck cat hot cat
- big joam
- tremulus lune
and many more..
Post by O.B.Y »
Dirk_Hendrik wrote:No.
so... have you built it?
Nope. I undid unverified it! Much less harder funstuff :horsey:
O.B.Y
- balck cat hot cat
- big joam
- tremulus lune
and many more..
Post by O.B.Y »
Dirk_Hendrik wrote:Nope. I undid unverified it! Much less harder funstuff :horsey:
ya i cant find for the potentiometer with lower value..
so can u give me for the solution??
Fix_Metal
Been thanked: 15 times
Post by Fix_Metal »
K guys, I'm in a good mood on today.
On today I just brought to new life the M108, including an LT1054 inside, a footswitch, MTB2, tantalium caps changed over film caps. In the past I tried to mod it adding volume and gain slide pots. I drilled the box and so on. Since I had cracked the original writings, I stripped the box and painted it new. Same blue but I have no clues on how to restore the original font/white writings.
Anyway, check this out. This is the original schematic for the M108 Blue Box Version. Mine had (once) written MXR Graphic Equalizer, as you can see in my pic.
I've drawn and uploaded this schematic on diyitalia.eu, which is an Italian forum (I'm Italian), about a year ago. Never thought I'd publish it in here, that's why there is a "Permission refused blabla" in the pic.
Consider this to be my thanks to this great forum, where I found many detailed and ready-to-go projects.
The SN is: 804116
Enjoy :D
p.s. slide pots seems to be 20K linear. I measured'em one by one and the readings showed values from 14KOhm to 22KOhm.
