Reversed battery by accident in Aqua Puss - help needed
Postby TB-AV » 01 Sep 2009, 14:58
I mis-wired a battery clip to power the AquaPuss build. I simply wired a plug to a 9v batt. and mistakenly put + on tip.
The board was complete with transistors and all other parts but no chips. I got a dead short and didn't notice it until the battery got quite hot.
So I finally figured out what I did and corrected the battery polarity. Problem is I still have a short and battery still gets hot.
Any idea which parts might have likely failed so I can narrow things down?
Thanks.
Oh, also I have checked and rechecked several times for mis-wiring, stray solder, incorrect polarity of caps, diodes, etc. All lots correct and clean.
TB
TB-AV
Re: Reversed battery by accident in Aqua Puss - help needed
Postby lolbou » 01 Sep 2009, 17:10
If the battery short outside the circuit (in the clip), then no parts should have burn...
Desolder the clip, and check for any short between the two tracks (+9V and GND) with a multimeter. By the way, check your battery clip for shots too...
Let us know!
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 352 times
Have thanks: 240 times
Postby TB-AV » 01 Sep 2009, 23:00
Thanks, I got it taken care of. the only part to get damaged was a diode(D2). It's up and running now.
TB
TB-AV
Return to Debugging
