Behringer VM1 Vintage Time Machine
Re: Behringer VM1 Vintage Time Machine
Postby JiM » 25 Feb 2009, 23:15
fozziemusic wrote:Very nice actions so far! I'm quite an electronics newbie, so I'm unsure whether I can answer all questions, but tracing out leads with a dmm should be doable :) .
Thanks !
What i'm asking for is fairly simple. I had to make suppositions about the copper traces that run under the components (either in the shadow of electrolytic caps, hard to see under silkscreen despite the high quality pics, or worse, under the integrated circuits). I've highlighted these supposed traces in contrasting color on the images above, and they have to be checked. This can be done visually for some of them, and electrically for the ones that run under components. Just use your multimeter in "beep" mode, and touch both ends of a trace containing orange (or green) portions on the pictures above.
If it beeps, i was right. If it doesn't, there might be another pin nearby that does, and the supposed trace shall be corrected.
I think that i've already corrected most of them by comparison with available Memory Man schematics, and likeliness of the routing (shortest path for example). Verification is still welcome !
fozziemusic wrote:How do I see whether a cap is polarized?
It has a grey band with "minus" signs, towards the negative lead. This is about the only marking on the electrolytic caps to be seen on the pictures ...
It looks like only C20 doesn't have one, so i wonder if it is a non-polarized cap. It might have a "NP" marking.
Anyway, looking at the values of these caps is more important !
About the original questions :
  • Against clock noise, i'd try first to shield or separate the cables that run from the main board to the IO board. There are adjacent wires that carry audio to/from the jacks and LFO signal to the chorus/vibrato switch, the crosstalk might come from there.
  • About Delay CV, i'd try a vactrol (or homemade LED+LDR+heatshrink) in parallel of the Delay pot, which is wired as a variable resistance.
Here are the new files.
(btw, is there a way to update files, in order to keep the thread fit ?)
JiM
Has thanked: 31 times
Have thanks: 37 times
Postby fozziemusic » 26 Feb 2009, 16:08
These are the cap values:
c6 2a473j
c9 25v 47uf
c7 25v 47uf
c57 16v 10uf
c15 16v 10uf
c13 50v 1uf
c12 16v 10uf
c11 16v 10uf
c16 16v 10uf
c56 50v 1uf
c18 16v 47uf
c19 16v 47uf
c30 50v 1uf
c52 50v 1uf
c17 50v 1uf
c39 50v 1uf
c20 50v 1uf
c23 16v 47uf
c22 50v 1uf
c21 50v 2.2uf
C20 looks different from all the other ones, can't find a marking that indicates polarity (all other caps are black or very dark blue and have "0>0>" marking on one side from top to bottom, c20 is lighter blue and doesn't have this mark).
I'll try to get the other answers as well. Thanks for the suggestion of the leads, worth a try as it's so simple to test :D
fozziemusic
Postby fozziemusic » 26 Feb 2009, 16:45
Oh, I forgot pot values:
vr4 = vr5 = 22k
vr8 = 10k
vr9 = vr10 = 100k
vr3 = 50k
vr2 = 10k
vr1 = 1M
fozziemusic
Postby JiM » 02 Mar 2009, 21:26
Great !
I've updated my schematic with the values, but before posting it again, did anyone find mistakes in the previous one ?
There should be some protection diode and filtering cap on the I/O board, this schematic bit is a pure supposition :roll:
JiM
Postby Dirk_Hendrik » 03 Mar 2009, 10:06
1st impression,
I'm having trouble with orientation and type of D1. I's expected it to be a zener diode.
Has thanked: 255 times
Have thanks: 1033 times
Postby JiM » 03 Mar 2009, 19:50
Thanks Dirk, you're right ! :thumbsup
I must have copy-pasted too fast ... it's D4, and it's a 8.2V Zener in the opposite direction, cathode to the base of T5.
I expect D1 to be the reverse-polarity protection diode, on the IO board.
JiM
Postby fozziemusic » 31 Mar 2009, 22:26
Sorry for my silence, it's been crazy at work so I haven't been able to do more work yet. I hope to do the schematic checking, but it may take a little while....
fozziemusic
Postby Uma Floresta » 17 Apr 2009, 15:33
*Watches with interest*
:applause:
Uma Floresta
Postby Entrant_21 » 26 Apr 2009, 23:51
How does this fare compared to a Memory Man?
Any mods to convert this to MM specs perhaps?
Cheers
Entrant_21
Have thanks: 3 times
Postby JiM » 27 Apr 2009, 22:30
Entrant_21 wrote:How does this fare compared to a Memory Man?
Cheers
It should be a straight copy. But of which version :?: EHX is known for slight variations from batch to batch.
Here is the latest (still unverified) schematic.
If someone could trace the IO board, it's the last thing missing. Even if it looks done, it's pure speculation from me !
JiM
Postby wildschwein » 25 Jun 2009, 14:59
Has anyone got any theories or opinions about running these at 18 volts?
wildschwein
Postby JiM » 25 Jun 2009, 19:35
wildschwein wrote:Has anyone got any theories or opinions about running these at 18 volts?
You might get a bit of additional headroom from the preamp and compander circuit, but none from the BBD stages :
  1. because of the aforementionned compander
  2. because of the discrete voltage regulator made of T5 and D4
I don't think it's worth the hassle, as you might overdrive the input of the BBDs. Or you'll have to also change D4 to suit the acceptable supply voltage of the BBDs ...
What's your goal in increasing the voltage ?
JiM
Postby wildschwein » 26 Jun 2009, 11:02
Increased headroom was what I had in mind.
wildschwein
Postby user007 » 03 Oct 2009, 14:37
One little question:
My Behringer VM1 is not true bypass.
I need help to my circuit. Which parts must be change , wich components remove.
I want to insert a DPDT sitch with Millenium Bypass.
I cant't read this in the schematic.
Thanks.
user007
Postby airfrankenstein » 10 Dec 2009, 13:59
Just got a VM-1, satisfied overall save for the weak modulation.
Was wondering if changing the value of the vibrato/chorus pot would change anything ?
Or maybe there's a specific trimpot to tweak ?
airfrankenstein
Postby Scruffie » 03 Apr 2010, 03:57
I was just looking at this as a possible doner case if I DIY'd a EHX Deluxe Memory Man with V3205s and noticed that no one seems to have mentioned that this uses a V3102 rather than the 4047 of the Memory Man so it's not a straight clone.
Then comes my next question, can you use a 4047 to deliver the clock to V3205s or did they choose not to from a design point... will it work just as normal or do I need to switch the outputs or something?
Scruffie
Has thanked: 28 times
Have thanks: 144 times
Postby Dirk_Hendrik » 04 Apr 2010, 11:13
Good observation.
As long as you make sure the clock amplitude voltages delivered by a 4047 are the same replacement of the 3201 clock circuit by a 4047 circuit (the original DMM clock circuit) should work. Bear in mind you'll still have to find an alternative to generate the Vgg voltage as well.
If, and I say if, a 4047 is able to give a stronger clock output when driving 2 BBD's, it might be that the BBD's are driven "better" and therefore give a cleaner delay signal. This could very well be the case.
Postby Scruffie » 04 Apr 2010, 23:55
Thanks.
From what i've read i'm led to beleive the 3201s are limited to the amount they can drive, so a 4047 may deliver a stronger output yes... Also the 4047 is cheaper.
I think it will be doable but i'm gunna have to do some actual research.
Scruffie
Postby ssmc » 25 May 2010, 16:19
Scruffie wrote:Thanks.
I don't know for sure but I think that MN3201 is "quieter" than 4047.Or at least it is made for MN3005/3205 IC.
ssmc
Have thanks: 18 times
Postby Dirk_Hendrik » 25 May 2010, 20:40
Help?
The MN3102 provides a supply voltage and to antiphase clocksignals to the BBD chip. What exactly would make it quieter??
PreviousNext
Return to Pimp-My-Cheap-Pedal
