BAJA Black Toast
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Thank YOU too Ivan
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
so that layout has now been used by me - does that make it verified.. ?
I have to admit to my embarrassment that I really don't know what a buffer does, but the signl passes through so I guess I got it right?
pics.
I REALLY like the boost. I have a $5 NASTY power supply I use for testing and it picks up 50Hz hum terribly but this pedal just does not seem to produce it.. the boost is very clean, and just somehow gives the tone more life.. again, thanks to you Steve.
pics.
- bajaman
Hey - glad to see you built and like it Ivan.
For your info - the buffer is like a sort of "no man's land" - on one side we have high impedance and on the other side we have low impedance (the output ).
Okay, now low impedance means more current is available to drive the next effect or amplifier input that the buffer is connected to, WITHOUT influencing any device connected to the input (for example: wah wah pedal).
It is almost like nothing is physically connected - almost like a form of automatic transmission in a motor vehicle
In practice with a simple Jfet buffer such as this you typically loose up to 10 % of the signal passing through it - no big change in perceived signal level though. What is rather neat, is that you can now turn the buffer output level down without affecting the high frequency response, unlike most guitar volume controls where a significant high loss is encountered. This means you can set the level at say 70% with the buffer on and set your amplifier gain controls a little higher to compensate - then when you turn the buffer off, you have the full volume of the guitar available again, and this can also give a nice preset boost for a clean solo when desired. The boost of course provides a far hotter, but very transparent boost above this. So there you have it - clean, crunch and over the top in one small jfet based pedal.
Where possible please use the 2SK117 for most neutral coloration. Available from MCM Electronics - thanks soulsonic
As Bjorn always says - have fun
- rocklander
- Contact:
I'll play with it a bit more and see if I can figure it.. when I had it on the bench (couple of weeks ago) I seem to remember the buffer pot making a noticeable difference to the volume, but I only just got the 3pdt toggle for the buffer today (delay from futurlec - they've been very good otherwise) and put the unit in the box and I'm not feeling it.. perhaps I've transposed the wires on the pot
I'll look at it again tomorrow.
I used the 2sk117.. got them from futurlec
nice explanation of the buffer too thanks.. I think I get it now
- Greenmachine
- my favorite amplifier: Fender Blackface Deluxe Reverb
- Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor - Location: Jersey City, NJ
- Has thanked: 87 times
- Been thanked: 17 times
- Contact:
Sexy looking decal. How do you do that? My pedals are as bare as an elephant's ass. I guess that's cool if you're into mysterious and minimalist; but I like a bit of color and gloss.
"[Y]ou want sketchy, dude? I breadboard on a door." -- RnFR, 2011
"This amp is freakin loud, like crazy, I'm going to kill pets loud." -- mich, 2011
- rocklander
- Contact:
- bajaman
- rocklander
- Contact:
righto.. how'd I miss that? (cos I'm SO known for my attention to detail )
- Greenmachine
Roger Mayer Octavia
MXR Phase 90
DOD FET Preamp
BYOC Analog Delay
Anderton Mini Amp
Keen Neovibe
Aquapuss Delay
DOD 280 Compressor
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
- Contact:
Yeah Bajaman; that's the one. Do you use some kind of iron-on image transfer paper?
- bajaman
Hi Greenmachine
I make all my labels (especially one off custom designs) by first, using CorelDraw (photoshop is similar), a great graphic design program. As with all software, the more time you put into using it th, the more professional the results obtained
Then, i print the label with my inkjet printer onto EPSON photo quality ink jet paper ( NOT just cheap paper ).
Then I laminate it with an "el cheapo" hot home laminator. I then cut out the label with scissors and spray glue 3M (small aerosole can) onto the back of it and using a piece of A4 paper with a (slightly smaller than the label) hole in it carefully spray the chassis top panel. After 5 minutes I press the label onto the case - job finished.
Alternatively - I use double sided sellotape or Nitto 500 professional roll adhesive (from a local screenprinter).
- marmora
- Completed builds: Distortion +
EA Tremolo
Mingrod
Honeytone speaker out mod
Line 6 DL4 and MM4 mods
Boss AC-2 clone
Sparkleboost
BSIAB II
Lofo Mofo
Jawari
Psychtar
CMOS Nyquist Aliaser
Paralooper
Punch-In-The-Face
Gargletron
Omni Drive
Blue Magic
Boss SG-1 clone
Parapedal
Feedback Looper
PEEPlug
ST-C Delay
Casio PT-100 bends
Riot Zone
HT8950A modulator
Blast Fed Disaster
Crushed Glass
Mac Oscilloscope
Gristleizer
Atari Punk Console
Dub Siren
UM3561 Siren
Bent Radio Shack Playtime Keyboard
Bent Animal Band Keyboard
Bent Barbie Karaoke
Rebote 2
PWM
Distortus Maximus
Woolly Mammoth
Phase 45
Dr Boogie
Femtoverb
Random Number Generator
Mayhem!
Uglyface
Bent Casio SA-40
Clari(not) Cubed
Black Toast
May Queen
Bent Speak and Read/Math
Thing Modulator
Geofex Low Fidelity/Noise/Telephone
Lovepedal Woodrow
Bazz Fuss
Bent Vtech Alphabet Desk
Bent Realistic Rap-Master
Noise Box (modded Lofomofo, Noise Ensemble, Dirty Sanchez)
Robobuddy - Location: Chicago
- Has thanked: 1 time
- Been thanked: 4 times
- Contact:
I finally got my Black Toast built. Thanks for sharing with us bajaman!
I found I had to go even lower than 3.3k for the drain resistor on the booster section. A trim pot is a good idea here as mentioned.
I've only finished it a few hours ago, but like what I hear on both guitar and bass.
- rocklander
- Contact:
wanted to use just the buffer part (as discussed here) so I used Jurano's advice (thanks!) and made a wee layout.. will be building/testing this week. just used a 10K fixed resistor instead of a pot cos it will be 'always on'.
layout pcb expressPCB file
- Lucifer
It's a pretty simple layout - and it would benefit you greatly if you could check it through and verify it (or not) for yourself.
You'll feel a lot more confident in your abilities that way, rather than someone giving you the answer on a plate.
Trust me, it's great fun
- swt
Hi baja. I'm really enjoying this circuit. The buffer is amazing and can cut noise from ground loops...etc in some noisy stages. Where would you put a simple treble attenuation? It's too pristine clear with fender amps...do you recommend a cap to v+ from drain of the boost...a cap to ground from gate of 2nd buffer...or a trimmer and cap to ground before tge 10k volume pot from last buffer?
Thanks a lot for a great design and for your suggestions...
- bajaman
Hi swt - i would try your last suggestion first.
Steve
Steve
