BIG JAM schematics
BIG JAM schematics
Postby BMF Effects » 21 Dec 2008, 06:21
Happy Holidays! Image
Missing the SE-10 Tuner and SE-18 Parametric EQ. If anyone has either I'll add them to the package.
Big Jam schematics download via RapidShare or Big Jam schematics download via MegaUpload.
For this message the author BMF Effects has received thanks:
travsbluz (05 Oct 2011, 03:53)
BMF Effects
Re: The (almost) complete Big Jam schematics files.
Postby PurplePeopleEater » 21 Dec 2008, 10:25
Let me be the first to say "Thank You" !
PurplePeopleEater
Have thanks: 2 times
Postby borislavgajic » 21 Dec 2008, 11:53
:hug: secound....thanks
boris
borislavgajic
Has thanked: 140 times
Have thanks: 252 times
Postby DiscoFreq » 21 Dec 2008, 12:44
You beat me :)
I suppose you bought them or some Big Jam effects on eBay?
I received the copies with some effects I bought from that seller (twice).
I also bought the service manuals for all the Maestro effects of the Total Foot Control series (designed by Moog), I hope to put them online soon :D
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
DiscoFreq
Have thanks: 26 times
Postby TubeDude22 » 21 Dec 2008, 16:45
Thank you! :D
TubeDude22
Has thanked: 18 times
Have thanks: 17 times
Postby BMF Effects » 21 Dec 2008, 17:10
DiscoFreq wrote:You beat me :)
I bought the schematics a few months ago but needed to scan them. I kept saying to myself, "I'll scan them tomorrow". :roll:
I *think* I have most (if not all) of the Maestro TFC series stuff as well. If you run short on anything, let me know and I'll check.
BMF Effects
Postby DiscoFreq » 21 Dec 2008, 18:28
I have the service manuals for the complete series, but it's a small one: only 5 pedals:
http://filters.muziq.be/model/maestro/tfc
DiscoFreq
Postby bajaman » 21 Dec 2008, 21:04
Thanks for the reading material folks :wink: :applause:
Has thanked: 460 times
Have thanks: 1588 times
Postby dr » 22 Dec 2008, 02:44
....could someone convert them into a JPEG or GIF file and send me a copy? I can't get mine to work....Thanks!.......dr
dr
Postby BMF Effects » 22 Dec 2008, 03:35
dr wrote:....could someone convert them into a JPEG or GIF file and send me a copy? I can't get mine to work....Thanks!.......dr
Uploading. Will edit post with link when complete.
BMF Effects
Postby BMF Effects » 22 Dec 2008, 04:19
Couldn't edit the post. If one of the mods wants to take care of it...
Big Jam schematics in JPEG format.
BMF Effects
Postby dr » 23 Dec 2008, 00:03
.....thank you so much!...I should be able to repair/troubleshoot my Jazz Flanger now; again, THANK YOU!!!...........dr
dr
Postby soulsonic » 23 Dec 2008, 04:01
The Space Driver looks interesting!
Has thanked: 56 times
Have thanks: 280 times
Postby FearlessFlyingFrog » 30 Sep 2009, 18:20
soulsonic wrote:The Space Driver looks interesting!
I got the SE-12 Chorus and I like it.
I'm trying to understand what exactly the Space Driver does, but I can't really figure it out.
I'm still just a guitar player, trying to get a little deeper into music electronic.
Could somebody enlighten me a little bit.
What about those two MN xxxx CMOS chips? Are they obsolete?
FearlessFlyingFrog
Postby Dirk_Hendrik » 30 Sep 2009, 18:52
Nope. Not al all.
But refer to them as 4011 and 4007UB (so without the manufacturer specific prefix) and your search will be easier ;)
Has thanked: 255 times
Have thanks: 1035 times
Postby FearlessFlyingFrog » 30 Sep 2009, 19:28
Dirk_Hendrik wrote:Nope. Not al all.
Thanks, Dirk.
Could you give me a little hint on how this circuit works?
I'm still new on the CMOS field...
FearlessFlyingFrog
Postby JiM » 30 Sep 2009, 23:07
Thanks, Dirk.
The NAND gates of the 4011 are used as a flip-flop to command the bypass from a momentary switch.
The CMOS transistors of the 4007 are used as analog switches, again for the bypass circuit.
FYI, some DOD pedals use the 4007 to build a flip-flop too (two back-to-back inverters).
JiM
Has thanked: 31 times
Have thanks: 37 times
Postby celadine » 01 Oct 2009, 02:45
The space driver looks like a compressor combined with distortion. If you ignore all the CMOS, it will be more clear.
celadine
Has thanked: 16 times
Have thanks: 16 times
Postby FearlessFlyingFrog » 01 Oct 2009, 10:31
Thanks for sharing your knowledge.
Now I get it (partially at least).
Never really dealt with CMOS-switching before, since most schematics just exclude it.
Quite complex but interesting.
However, now the circuit doesn't appear quite as "spacey" as before.
FearlessFlyingFrog
Postby RnFR » 01 Oct 2009, 19:39
the drive control is a bit different. i wonder what the advantage is to that configuration?
Has thanked: 150 times
Have thanks: 174 times
Next
Users browsing this forum: No registered users and 21 guests
