Anyways,
When EHX started off with the nano series a couple of years back this picture howed up.:
Nice! But a photoshop. As I understood that caused some tears at TGP. Fine. Harden up a little. However I did expect EHX to show up with the DMM in a Nano style and they did. The DMM, the (Horrible) DMM with Hazarai, and the much more back to basics Memory Boy. But they did not do it in a 1590B style case.
This left me wondering wether the concept, DMM in a 1590B, could be done. Not the same as that photoshop for sure. Technically impossible and it lacks a control. But still... can I get that to fit.
Which made me thinking what to do to make it fit.
Change 1: Change over to MN3205 BBD's, ensuring it is possible to build one without having to hunt for 3005's. I never design with scarce components of which I do not have a shitload at hand.
Change 2: Easy. Adapt to 9volts negative center supply power.
Deliverable 1: The DMM is not battery powered! Neither does the project have to be, giving a load of extra boardspace.
Change 3: 2 LED's (power and overload)? Make that 1 duo led.
Can it be done? Yes it can:
I'll post some guts tomorrow. Don't ask for a schematic, the DMM schem is on the web. The only difference is the BBD's and the BBD's supply voltage control (Ibbie AD9). This is a case of engineering to get the parts to fit, not to get the circuit to sound.
Then,
I am aware this IS a serious infringement of the EH/New Sensor trade dress. Let em be assured this is in no way expected to be a production pedal and should be considered a parody.
ps,
Boris,
This is the one I promised you.
