Yamaha - DG-Stomp  [schematic]
rcustoms
Has thanked: 363 times
Been thanked: 520 times
Post by rcustoms »
round and round
yamaha stomp.jpg (9.63 KiB) Viewed 2456 times
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Post by rcustoms »
schematics
DG-Stomp_E.pdf
(1.48 MiB) Downloaded 439 times
snyder80
Post by snyder80 »
Hi!
Thanks for shring your detailed Information for this "oldie";)
But maybe this topic should be moved to the DSP-section, because its a digital device... :twisted:
Greetings,
snyder
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 51 times
Post by Hides-His-Eyes »
2 DSPs and a GPP? Love how far we've come!
johnsteb
Post by johnsteb »
Many many thanks for the yamaha DG-stomp schematics. I lost the powerpack and hesitated to buy a new one, if at all possible. I love the Stomp and always use it when on a gig so I happened to have this 15 volt AC powerunit (instead of 12 volt) but hesitated to use it, not knowing if the DG stomp would have sufficient regulation. However being a Yamaha i trusted this would be neatly taken care off. Seeing the schematics i give it a shot. Again, many many thanks!
John
crashguitar
Completed builds: Fuzz Factory, Red Llama, Calari(not)
Post by crashguitar »
I still use one of these as well.
I had to replace the power supply and found this one: http://www.apogeekits.com/12v_ac_power_adapter.htm. It works great.
Chad
facebook.com/ablearcher
atreidesheir
Has thanked: 441 times
Been thanked: 44 times
Post by atreidesheir »
Hides-His-Eyes wrote:2 DSPs and a GPP? Love how far we've come!
johnsteb
Post by johnsteb »
[quote="crashguitar"]I still use one of these as well.
Chad
facebook.com/ablearcher[/quote
Thanks Chad,
living in Europe I needed a 220 volt supply and as I was convinced the 15 volt supply would work, I waited till the last moment before a gig to try it out...... Fortunately a bad smell warned me this was a bad idea. From the diagram I should have figured that the stabiliser is of the old type, internally dissipating all excess voltage and getting very hot in this case. Fortunately no damage was done, I ended up modifying a redundant Linksys router power-supply by removing the rectifier board. Works excellent. Thanks again.
John
Duckman
Has thanked: 320 times
Been thanked: 134 times
Post by Duckman »
Sorry 'bout my noobness, but what is the function of D101 and D102 @ the input opamp?
Tkx!
