EHX - Freedom Pre-Amp  [schematic]
Dr Tony Balls
Been thanked: 172 times
Post by Dr Tony Balls »
Anyone know whats inside one of these?
Ive never heard of one and never seen a schematic. A person or two on the DAM forum seem to have them so im trying to get gut-shots of one.
Scruffie
Has thanked: 28 times
Been thanked: 170 times
Post by Scruffie »
I've got a schematic for the actual Amp I think but not the seperate Preamp, never knew it came like that.
Dr Tony Balls
I wonder how different the amp is, or if it is at all (preamp-wise, anyway)
uncleboko
Has thanked: 58 times
Been thanked: 41 times
Post by uncleboko »
I should think it's the same - the amp had tone and bite controls, also the Dirt Road Special amp
darthoverdrive
Has thanked: 121 times
Been thanked: 87 times
Post by darthoverdrive »
Dr Tony Balls
found a bunch more of what looks to be the same unit here: http://stompboxes.co.uk/forum/viewtopic.php?f=6&t=11956
im starting a trace.
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
Trace it up!
Image Ken
Dr Tony Balls
Hrmm....im at kind of a loss here because of the trim pot on the solder side blocking a big chunk of the view. Anyone have any ideas? Here are my pics of where I am now. I'm assuing the IC is a dual op-amp.
front by thetonyballs, on Flickr
The schematic looks odd, too....not sure if its making sense
phibes
Post by phibes »
Yeah it'd be way easier if that guy could take pics closer to the trimmer. I'll look closer later.
I was guessing this thing would be similar to a Boss FA-1.
Image Ken
Dr Tony Balls
Also in that schematic fragment R10 and R7 are supposed to pots, and every line pointing down is a ground connection. DIYLC doesnt have those things, it seems.
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 51 times
Post by Hides-His-Eyes »
You should be able to work out those last few connections based on the pinout of the op-amp. It needs to get power, and the signal goes towards inputs and away from outputs.
Duckman
Has thanked: 320 times
Been thanked: 134 times
Post by Duckman »
I'm not 100% sure, but in this picture, looks like there's nothing connected to pin4 and pin8 and both 4k7 resistors goes to pin7 and 10k goes to pin6, maybe pin5, too. :scratch:
Dr Tony Balls
Duckman wrote:I'm not 100% sure, but in this picture, looks like there's nothing connected to pin4 and pin8
I think those go to ground and +V, respectively, but the trace is underneath the IC.
Duckman
Post by Duckman »
Right :slap: Pin4 goes to the black wire, presumable ground :?:
Surely, the trace between legs, from the down side, to the 47k resistor in the 5087 emmiter carries power from pin8.
Duckman wrote:both 4k7 resistors goes to pin7
Wrong. Just one does.
Dr Tony Balls
I believe the black wire it actually +V. Theres that large pad just above the IC that should be ground, and it doesnt appear to connect to it.
Duckman
Post by Duckman »
Mmmm... We're preassuming that's a dual OA... and we got a 5087 PNP device... I'm confused about V+ and V- right now :scratch:
Been thanked: 124 times
:hmmm: :hmmm: :hmmm: Where do you see a problem ?
Electro-Harmonix Freedom Pre-Amp schema
Quod erat demonstrandum,
Duckman
Post by Duckman »
analogguru wrote:Where do you see a problem ?
Apart of my noobness? The time you take to post it :lol:
I didn't see a problem, just was confused :blackeye
Sciens minus potest cognoscere :oops:
phibes
Post by phibes »
AG!
Image Ken
uncleboko
Post by uncleboko »
"Quod erat demonstrandum"
Et Dirtus Roadus Specialus est :applause:
Locked
