Pro Co - Juggernaut  [schematic]
dosmun
Post by dosmun »
Here are some gut shots of the Pro Co Juggernaut. If someone wants to draw this out contact me and I will try to help with values etc. FYI both of the IC are MC1458's
salocin
Been thanked: 7 times
Post by salocin »
Any chance you could get a slightly lighter version of the first photo? In the area where the opamp is, just above and to the right of the foot switch, I personally have a hard time telling which bits are joined. Not sure if that's just me though?
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
thanks Dosmun..... :thumbsup
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
Awesome!
Rocket Roll
Been thanked: 38 times
Post by Rocket Roll »
dosmun
Post by dosmun »
I will get some more info as far as values etc. hopefully over the weekend.
Stompmodder
Been thanked: 5 times
Post by Stompmodder »
A Bass Ratt!! Yes! :applause:
Please let us know your impression about the sound of this effect.
dosmun
Post by dosmun »
I only played it a little bit but it sounds more like a traditional fuzz than a Rat when you crank the distortion up. It actually is on the edge of being sputtery.
dosmun
Post by dosmun »
Her are some values. I roughly measured the pots in circuit and they all appear to be 100K except the 2nd one from the left which is 50K.
All green caps are .022
All ceramics are 100pF except cap to far left by opamp it is 30pF and the one at the top middle by the diode is .01uF (103)
There are 3 values of Electros:
The large one at the far right is 47uF
Smallest ones are all 10uF (6 of them across the middle of the circuit
Larger ones are 100uF (4 at the top and 2 at the bottom of the circuit
Transister is 5458
Opamps are MC1458's
noelgrassy
Post by noelgrassy »
Interesting pedal. 8) I see where the PC sez, "Re-Issue". I don't remember these at all for some reason. What years did they first exist in? Isn't it designed primarily for the bass? Thanks for the great detail in the pics. I'll bet some folks will want to build these even if they are priced affordably.[relatively speaking of course]
OT: I opted for the DeuceTone. It actually sounds quite a bit better than I remember my Rat ever sounding. They've implemented slide switches in each channel to approximate the Grandlaff's diode switcher. They're pop-rivetted to the case :scratch: and one of 'ems skewed :roll:
This is probably in keeping with their "bullet-proof" design model. A tiny toggle can be rendered useless with an occaissional python boot. Plus, they probably cost at least twice as much as a SPDT slide switch.
The channels can be run in series or as 2 separate voices of distortion. Which more than makes up for the regretably oversized footprint.
dosmun
Post by dosmun »
Check out my Rat history page for more info and some pics of the early Juggernaut
http://webpages.charter.net/daosmun/
dosmun
Post by dosmun »
If anyone is interested in buying one, there is one that is ending today on Ebay and looks like it will go cheap. https://cgi.ebay.com/ws/eBayISAPI.dll?V ... :IT&ih=016
dosmun wrote:If anyone is interested in buying one, there is one that is ending today on Ebay and looks like it will go cheap. https://cgi.ebay.com/ws/eBayISAPI.dll?V ... :IT&ih=016
Looks like I won! Many thanks, sir! :D
Now I will be able to guarantee us an accurate trace.
Fuzzer
Been thanked: 21 times
Post by Fuzzer »
You sir, are great.
Bernardduur
:thumbsup
dosmun
Post by dosmun »
I won mine just a couple of days ago as well. $60 shipped. Mine didn't work but was new. Problem ended up being a nut missing under the board where it mounts to the pots so it was shorting against the case.
You don't see these very often let alone for under $100. Congrats on the deal Soulsonic.
anyone want a PCB clone for the Juggernaut :?: - let me know if interested :wink:
Here is the Juggernaut ready to etch PCB - 1200 dots per inch resolution - scale is in tenths of an inch
members/bajaman/JUGGERNAUT/BAJA%20ProCo ... %20PCB.png
Bernardduur
Awesome;
Now we onlu need to figure out what goes where :)
