Pro Co - Solo
dosmun
Post by dosmun »
Silly question but is anyone interested in the Proco Solo? I will try and post some gut shots over the weekend. I know the switching section is riveted to the case or something like that so getting gut shots of that will be hard, but I did sketch out the schematic for that section a year or so ago so I will dig that up.
More to come............... :thumbsup
Has thanked: 218 times
Been thanked: 857 times
Best way to determine wether there's interest is by posting the photo's. There's quite a few here, of various ages, nationalities and swapped citizenship that like to lurk here but dont have the balls to post.
But to give you a straight answer just as well. Yessir, I'm interested. :mrgreen:
:wink: bajaman
A friend of mine has one of these - it's crazy intense distortion; not like any Rat. Very "modern" Heavy Metal.
Bside2234
Been thanked: 88 times
Post by Bside2234 »
I too would like to take a look at it.
dosmun
Post by dosmun »
~arph
Has thanked: 60 times
Been thanked: 163 times
Post by ~arph »
:shock: the soldering :shock:
the soldering
yes - no machine soldered smd here - through hole technology done by hand - I have never had to resolder a dry solder contact in any of ProCo's products - period!!!
Cannot say the same for the crappy "X wing" switches they used to use though :wink:
~arph wrote::shock: the soldering :shock:
It definitely needs a flux cleaner bath. Components are mounted sloppy too. Overall, it looks very rushed.
bajaman wrote:Cannot say the same for the crappy "X wing" switches they used to use though :wink:
Good to know I'm not alone ;) :mrgreen:
Thanks for the pics dosmun!
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
very nice :applause:
:hmmm: ..... ok..... :hmmm: ..... then here is the
Pro Co - Solo PRELIMINARY schematic
Sadly some component values missing yet.
enjoy,
I have the main board layout and PCB almost ready too.
Thanks Dosmun :wink:
Any help identifying the resistor, pot and capacitor values :?:
Here is the main PCB.
Thanks Dosmun - how are those component values coming along - I have the overlay ready to upload when all values are known.
members/bajaman/SOLO/Solo_main_PCB.png
Here is the diode PCB and overlay - both 1200 dpi
members/bajaman/SOLO/Solo_diode_PCB.png
members/bajaman/SOLO/Solo_diode_overlay.png
dosmun
Post by dosmun »
The blue diodes are a GE diode that ProCo also uses on the Dirty Rat. I will get some values tonight when I get home from work.
dosmun wrote:The blue diodes are a GE diode that ProCo also uses on the Dirty Rat. I will get some values tonight when I get home from work.
I DON´T believe that they are GE-Diodes, instead I assume that they are schottky diodes which seem to be marked "CD SH 270".
dosmun
Post by dosmun »
I can't see any of the markings on the Blue diodes and the board is riveted to the case. The ProCo site says the Dirty Rat uses GE diodes and they look like the ones in the Solo. http://www.ratdistortion.com/history.htm
dosmun
Post by dosmun »
Bajaman, do you have a overlay with values for the main board? It would be easier that way to give you the values you need. I have the caps figured out but not sure what would be the easiest way to give them to you.
