Ibanez - FL-9 Flanger  [schematic]
Been thanked: 124 times
Here some guts of the Ibanez FL9 Flanger:
and here is the factory schematic:
http://www.mojotronics.com/images/FL9.pdf
FL9(2).pdf
Ibanez - FL-9 Flanger schematic
(271.19 KiB) Downloaded 615 times
puppiesonacid
Been thanked: 12 times
Post by puppiesonacid »
cool, thanks ag. the FL-9 is one of my favorite flangers aside from the mxr and the FOXROX TZF. It also can get really good chorus sounds as well.
jalexquijano
Post by jalexquijano »
I just got my ibanez FL-9 made in Japan yesterday. Is it worth changing the LED to a brighter 3mm red one? Or should i leave it as it is?
Greenmachine
my favorite amplifier: Fender Blackface Deluxe Reverb
Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor
Has thanked: 87 times
Post by Greenmachine »
Whatever floats your boat.
"[Y]ou want sketchy, dude? I breadboard on a door." -- RnFR, 2011
"This amp is freakin loud, like crazy, I'm going to kill pets loud." -- mich, 2011
Has thanked: 232 times
Been thanked: 888 times
What exactly does the "made in Japan"mean. All FL9's were made in Japan. Unless you have a reissue which means it would be more worthwile mentioning that.
Better lower the value of the zener in series with the LED.
borislavgajic
Has thanked: 131 times
Been thanked: 281 times
Post by borislavgajic »
http://www.box.net/shared/md9ahno2fo
nice man from Novi Sad took this guts......so trace side is here now :D
which one is better sounding...this, or fl301(with MN3007)?
enjoy
Boris
FL9_service_manual.pdf
(271.19 KiB) Downloaded 784 times
might help too!
borislavgajic
might help too!
Sure do!....that was there for long time!!!! thank You mister Dirk :thumbsup
so what do you people prefer MN3007 or MN3207 flangers ..?
stupid question, but please reply :block:
Boris
borislavgajic
http://pdf1.alldatasheet.com/datasheet- ... C1583.html
how to replace this with common transistors?
is it possible?
thanks
Boris
lolbou
Has thanked: 308 times
Been thanked: 225 times
Post by lolbou »
These are built-in "difference amplifier". You can replace them with two identical NPNs connected as shown I believe, though you may need to get the specs close enough. Maybe a good result could be expected from an opamp actually?
In a thread here, Dirk mentions that the FL5 is a dead-on copy, I'll take some gut shots to post in the other thread and check for any replacement part...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
borislavgajic wrote:http://pdf1.alldatasheet.com/datasheet- ... C1583.html
is it possible?
thanks
Boris
jep.
Just take 2 transistors from the same production line. Ibanez quit using those in the AD99 already.
lolbou
Post by lolbou »
lolbou wrote:and check for any replacement part...
It seems that two 2SC1815s are making the job in the FL-5. :wink:
ps: guts posted in the FL-5 thread...
Redhouse
Post by Redhouse »
is it possible?
thanks
Boris
Maybe?:
LM394
MAT02
MAT12
rrroo
Post by rrroo »
this is a great flanger, but i noticed a problem. the oscillating noise bleeds through when effect is bypassed. is there any mods that could help this (except using a bypass looper, of course)..
replace C132 and C135 (47uF/ 6.3volts) first
bucksears
Has thanked: 16 times
Been thanked: 41 times
Post by bucksears »
Resurrecting this one with an interesting finding:
I just got an FL-301DX (9V) on Monday (2nd one I've owned). It has a really noisy 'swoosh' (like air blowing), but the flanging works fine, so I opened it up to have a look. It also runs the MN3207. After taking hi-res shots of the solder side, I noticed the layout is VERY similar (about 80-85%) to the FL9. I'd bet good money that the only major difference in the FL9 is the addition of the Delay knob.
My vintage/MIJ FL9 has some kind of grounding issue where the LED stays slightly on when bypassed, causing any true-bypass pedal attached to it to pop when switched on/off.
I'm recreating the PCBs in Illustrator (should fit in a 125-B), so I'll have a better idea of them in a week or two. Ideally, I'd like to build new ones minus the buffer/switching and compare them back to back.
Your problem description gives me the suggestion there is a resistance between the GND connection of the power supply and the GND on the PCB. This causes the circuit GND to float compared to the power supply GND and causes the output to have a DC offset. Hence the pops on other pedals.
bucksears
Post by bucksears »
Thanks Dirk - I'll have a look there first.
- Buck
partybox
Post by partybox »
Bump. Some more gutshot pictures. My Ibanez FL9 unit had two leaky caps and the dielectric juice took some paint off the PCB. So, I repainted the lines.
