SoloDallas - Storm
SoloDallas - Storm
Postby aionios » 18 Oct 2019, 16:08
The SoloDallas Storm is a pedal conversion of the audio path of the Schaffer-Vega Diversity System, a wireless guitar system from the mid-1970s that was used by stadium legends like Van Halen, KISS and AC/DC. In particular, Angus Young used it in the studio because he didn't feel like his guitar sounded right without it.
The Storm is based on a ton of research that SoloDallas did into the SVDS, picking apart the circuitry and eliminating the non-audio portions. SoloDallas has also released a full replica of the original tower which is both impressive and expensive in equal measure.
The attached schematic is for version 2 of the Storm, which was released this summer. I'm not sure what the differences were between this and v1, but compared to the earlier Schaffer Replica pedal, it replaces the compander with an optical limiter sub-circuit and adds the Limiter knob.
Really fantastic circuit, lots of warmth and squish with really high output.
Full tracing log here, including photos and more background info:
https://aionelectronics.com/blog/tracin ... las-storm/
PCB available here:
https://aionelectronics.com/project/gal ... r-limiter/
Aion Electronics - DIY PCB projects for classic and obscure circuits
For this message the author aionios has received thanks: 12
287m (18 Oct 2019, 20:25), alexradium (18 Oct 2019, 20:48), blackbunny (21 Oct 2019, 01:56), caspercody (18 Oct 2019, 19:40), deltafred (20 Oct 2019, 14:22), FuzzMonkey (20 Oct 2019, 20:50), Intripped (19 Oct 2019, 14:45), karul (18 Oct 2019, 21:14), Manfred (18 Oct 2019, 17:01), Zokk (19 Oct 2019, 21:54) and 2 more users
aionios
Have thanks: 151 times
Re: SoloDallas - Storm
Postby boby6kiler » 19 Oct 2019, 14:31
if you can do the same job with the tower it is nice :popcorn:
boby6kiler
Have thanks: 9 times
Postby bajaman » 21 Oct 2019, 03:07
shouldn't R7 be connected after C6 not before ? :!:
Has thanked: 467 times
Have thanks: 1661 times
Postby EddieTavares » 21 Oct 2019, 13:44
It's a modified Flatline Compressor;
For this message the author EddieTavares has received thanks: 2
Ben N (28 Oct 2019, 17:09), Manfred (21 Oct 2019, 15:28)
EddieTavares
Have thanks: 17 times
Postby aionios » 21 Oct 2019, 15:54
bajaman wrote:shouldn't R7 be connected after C6 not before ? :!:
Nope... it doesn't look quite right to me either, but it definitely does come before C6, straight off of IC1. Here is the board with components removed:
aionios
Postby aionios » 21 Oct 2019, 16:14
EddieTavares wrote:It's a modified Flatline Compressor
Very similar, although SoloDallas says that they traced the optical portion from part of the original SVDS which would have been 1976. Not sure whether or how much this portion of the circuit was adapted for pedal use, but optical compressors go back to the 1950s, so I would have a hard time believing the Flatline wasn't based on something earlier (or at least collage of a few different circuits).
aionios
Postby foxey » 21 Oct 2019, 17:29
it's OK?
foxey
Postby EddieTavares » 21 Oct 2019, 20:04
This one has no expander, maybe they believe that the expander portion are irrelevant to the tone.
EddieTavares
Postby Ben N » 27 Oct 2019, 09:30
If I am not mistaken, the purpose of the expander was to restore the original dynamics after compression for wireless transmission. It's not necessarily part of the "secret sauce".
BTW, the Solo Dallas account of all this makes absolutely no sense. The original product was the compander necessary for wireless; the new version is an optical limiter--both of which were (allegedly) in the original Schaffer-Diversity, but seemingly performing entirely different functions, but this is somehow an evolution?
Ben N
Has thanked: 24 times
Have thanks: 15 times
Postby boby6kiler » 27 Oct 2019, 11:46
foxey your layout look ggod to me
just some things i have see :
r20 andr19 you put a link but you don't and you can remove c1 and c5 probably
you don't have r21 so i presume your r5 is 1k
r17,c18,r18 and led is not show in the circuit just cable it outside
the name ic1 and ic2 is wrong
all the rest look ok to me
nice and compact thanks
boby6kiler
Postby foxey » 27 Oct 2019, 12:37
boby6kiler thanks.
The limiter doesn't work very well.
The noise is pretty loud, but it will be quiet when put in the case.
foxey
Postby foxey » 27 Oct 2019, 12:45
Sorry if wrong.
foxey
Postby bmxguitarsbmx » 27 Oct 2019, 19:44
Ben N wrote:If I am not mistaken, the purpose of the expander was to restore the original dynamics after compression for wireless transmission. It's not necessarily part of the "secret sauce".
From what I read from SoloDallas themselves is that you could control the compression, but the expansion was preset. Depending on which settings are mismatched, you would get something of the action of a transient modifier. Which to me seems promising, but is not represented in the circuit that has the commander circuitry.
Ben N wrote:BTW, the Solo Dallas account of all this makes absolutely no sense. The original product was the compander necessary for wireless; the new version is an optical limiter--both of which were (allegedly) in the original Schaffer-Diversity, but seemingly performing entirely different functions, but this is somehow an evolution?
From my reading of what Solo-Dallas wrote there is not only a commander circuit involved, but an optical limiter.
BMX
bmxguitarsbmx
Has thanked: 300 times
Have thanks: 94 times
Postby boby6kiler » 28 Oct 2019, 06:09
foxey if you try with the links in r19 and r20 just try without and tell us if it is better
boby6kiler
Postby boby6kiler » 28 Oct 2019, 12:45
foxey i think i have found your problem just reverse d2 d3 d4 d5 and it will work i suppose
boby6kiler
Postby foxey » 28 Oct 2019, 14:48
boby6kiler thanks for your advice.
This layout omits R19C1 and R20C5.
And the LED between BAT42 lights up only when playing the guitar.
It was like an LED used for clipping.
When the LED pin was reversed, it did not light up.
So I think BAT42 is in the right position.
But...
Is it correct that the LED lights only when playing the guitar?
foxey
Postby boby6kiler » 28 Oct 2019, 15:34
c6 is polarized in the original
boby6kiler
Postby foxey » 29 Oct 2019, 08:22
boby6kiler
That's the case in the photo that answered bajaman,
but it's different in the aion photo and schematic.
which is correct?
foxey
Postby boby6kiler » 29 Oct 2019, 11:32
just look the photo and retrace all that what i have done and i see just little erros in the schematic
boby6kiler
Postby foxey » 29 Oct 2019, 14:44
little errors?
:slap:
:secret:
please
foxey
Next
Users browsing this forum: MSN [Bot] and 10 guests
