Aguilar - Agro Bass Overdrive
- aegert
Hey guys was wondering if anybody has a schem or know what the aguilar od is based on. No pun intended!
Bass player in the band needs an OD and I heard this one sounded great. I could build up a OD and voice it for bass but this was spot on... Any help would be great... Thanks
Adam
Adam
- chicago_mike
- chicago_mike
The pedal is the same I think.
I might be able to get that schematic.
Skyline FX 2013
- Pruttelherrie
Are you sure this is the pedal? This looks more like the dirt channel of one of the heads that the Agro pedal is supposed to be based on. Symmetric power, 'channel' and 'deep' switches, FMV stack and all...
- Completed builds: Wooly Mammoth
Catalinbread SFT
MXR phase 45
Vox V845 (mod)
Boss Cs-3 (repair)
EHX metal muff (repair) - Location: Lodz, Poland
Hey Mikechicago_mike wrote:The pedal is the same I think.
Could you please share that schematic?
- modman
- a d m i n
- Has thanked: 4410 times
- Been thanked: 2139 times
Just counting the number of variable resistors (6?) in the schematic makes me wonder whether this is really the AGRO...but maybe some of them are internal gain trim pots? There are gutshots here, but you need to sign up to see full res versions of the pics..
https://www.talkbass.com/threads/show-y ... t-11660340
I'll retitle the thread and move it out of the request folder...
- x-tn
Is that a goop block?modman wrote:...There are gutshots here, but you need to sign up to see full res versions of the pics..
Yes, it's a goop block. The Tone Hammer has the same. Plastic outer frame, hard and shiny epoxy in the middle. You can see how some traces enter and leave the gooped area. If anyone is willing to teach me how to degoop without sacrificing my Tone Hammer, I might take a crack at this.
- deltafred
- Opamp Operator
When removing epoxy goop there is no guarantee that you will not damage something.
In fact there is a high probability that you will so if you if you aren't prepared to make good some damage then it is probably best not to attempt it.
The method is to heat the goop with a soldering iron and remove it bit by bit with dental picks and tweezers while trying not to destroy the components and tracks with too much heat and avoid picking the components off by mistake.
It is a long tedious job and the result looks a real mess but it is doable.
- george giblet
Why not trace it as is. It doesn't look like a lot of useful stuff is under the goop, if any.
After tracing you will have a few wires/tracks entering the goop. From the surrounding circuit
you can guess what might be in there.
(Maybe compare against Chicago Mike's schem. However, it looks different to the PCB.)
