Biyang Tonefancier Blue BL-8 [schematic]
I really like this pedal. I’ll work on a schematic in a bit but here’s pics for now. I’m wondering what it’s derived from.
It’s very warm (no treble), has loose bottom, very smooth, a ton of output. Only thing I could see wrong with it was some nuts were loose.
- Renegadrian
Did you manage to work the schem out!? it seems a little but funny circuit...curious to read it!
- EddieTavares
It looks like a proco rat without the output buffer and leds instead a diodes, it's easy to implement a tone control.
- CheapPedalCollector
I was about to say yeah, it looks like a RAT.
- Manfred
- Has thanked: 1671 times
- Been thanked: 1344 times
I made this PCB clone for tracing, can you please put the component values in the picture with the components.
- Renegadrian
Right! Just got one today for cheap, man let me say it's one of the worst pedal I've ever played! it can get some use with just a zic of gain, turn it up and you get lifeless mud sound...
- Renegadrian
- Manfred
This pedal is similar to the FAME Slasher DS-10, so I just had to edit its schematic.
viewtopic.php?f=1&t=30326&p=278466&hili ... er#p278466
Can you please measure the values of the potentiometers and the resistors?
- Renegadrian
gain is b100k and volume is b10k
- Manfred
Thanks, are the resistance values correct, have you already checked them?
- Renegadrian
Did you read my previous post!?
- Manfred
Yes I did, you wrote in the previous post:
Therefore I wrote:Got a problem with 1/8 metal resistors, quite difficult to read for me, guess it will be easy for others to complete the schem.
I think we are talking at cross purposes, did you measure values of resistors to confirm them?Can you please measure the values of the potentiometers and the resistors?
- Renegadrian
Right, I wouldn't read those damn resistors, I just measured with MM.
The previous image I uploaded has been updated.
Guess I'll transform it into a grey dod 250, it should be quite easy.
- Manfred
Thanks a lot!Renegadrian wrote: ↑31 Dec 2020, 14:53 Right, I wouldn't read those damn resistors, I just measured with MM.
- Manfred
Here the verified layout and the verified circuit diagram.
Super easy to add a tone control to that and make it into an overdrive with a couple 100k pots.
- Renegadrian
small correction on the schem, gain is 100k linear not log. please change accordingly.
- Manfred
The potentiometer type I have changed circuit diagram above.Renegadrian wrote: ↑01 Jan 2021, 01:26 small correction on the schem, gain is 100k linear not log. please change accordingly.
- wildschwein
Love this pedal -- huge thick tone with good sustain. Great with single coils.
