Thanks man! Really fudged the Tooth and Nail solo though
After hooking this thing up directly to my DAW that first time, I realized it really doesn't need any extra high end; the issue was running the cab sim through a cab itself; so like running a filter into another filter! Ended up sounding like a blanket was thrown over it, but not so much with the sim bypassed. More than enough high end available in this circuit.
For shits and giggles I also added the simple presence control from the Randall RG100es to the tone section after the rockman unit, and I like being able to turn down the high-highs while retaining the upper mids and lower highs . I do however, want to add some sort of active presence control utilizing NFB like in a 'real' amp, but am not 100% how to go about doing this. I always find presence to be an insanely underrated tonal control for guitar; and I find myself frustrated anytime I have to use a guitar circuit that doesn't utilize one.
For example; I have a small tube preamp I built based off of a 1968 superlead and Friedman topology. Initially its output was taken off a tube cathode follower, and no NFB was utilized. It sounded good, but missing something... so I kept redesigning the circuit over and over again, attempting to add NFB and a presence control from the cathode follower out, and creating a fake Phase Inverter stage to inject the NFB back into and yadda yadda yadda.... but I could never get it to 'feel' or sound the way the real one did.
Eventually, I ditched the 12ax7 output stage entirely, and added a REAL phase inverter, and a 6sn7 wired as a power tube, into a tiny output tranny. Boom; NFB and Presence control now easily obtainable, it only took 2 months of changing my tiny little diy build every single day, adding 2 additional tubes, and a freaking output tranny but I truly feel it sounds 'legit' now, and feels quite accurate to the real thing. Also, it can be used as a full 2-3ish watt amp if run into a cab so, pretty useful! Typically I just run it through a resistive load into my DAW though
