Carvindc125 wrote: ↑24 Nov 2020, 16:48
I am looking at the full schematic and admittedly I am not used to looking at a schematic drawn in this way. The switches and routing to them is throwing me off and confusing me.
Is there anyway someone could be an amazing over achiever and Draw the schematic in sections like the edge, dst, and EQ1 was laid out below? I am trying to understand how it all fits together. Where the clean 1 &2 input/output is How the EQ1 & 2 fit in with the Echo Trigger/Stereo Echo, and Chorus and trying to understand if the compressor is in the clean and dst/edg side. or just the dst/edg side.
Thanks a million in advance! Sorry for such a silly request but I learned to read schematics on my own and have trouble with bigger ones.
TLDR?
Requesting the clean 1 & 2 sections (EQ2, Echo Trigger/Stereo Echo, and Chorus) be drawn in sections like the example below.
Years ago I spent months back engineering the Nobels circuit long before I had a computer so it's do able if you have the patience or in my case the need. worth trying,,It's very good way to learn
I was quite surprised that years later I found the schematic on the web for the Nobels SST1 and my drawing was damn close to the factory drawing,,, but I'm not about to do that again,, LOL.
If enough interest I can make a drawing to simplify the signal paths but it is rather time consuming.
(Re signal path on the original drawing)
Unless I'm going blind the Compressor is on for all settings.
All settings pass through EQ1,,,Except for CLN2 which switches across to EQ2.
(EQ2 is IC104B)
The easiest way to follow the signal path is print the drawing out and highlight pen the path you wish to work out. (HINT)
SW101 is a 4 position switch so just join the dots for the 4 positions.
As drawn the switch is in Dist position,, the next position is EDGE which removes the loop back to pin5 of IC101B (the left side of switch)
It then joins EDGE and CLN1,, In this position left side of Sw grounds out R174 (3k3) while keeping C137 (15nF) in circuit.
While on the Right side of Switch,
CLN1 mode removes the output of IC102B (The Distortion) while still passing through EQ1. It also adds in R111(18k) & C107(10nF) to the signal path.
In CLN2 mode the right side of Switch engages EQ2 while Left side removes R174 (3k3)
FWIW, you can tweak this forever but in my humble observation,,As has been mentioned already there are likely much better compressor circuits around.
The one used here is likely tricky to setup and rather limited in ability.
The best part of this thing is the cab sim.
Likely easier to use a couple of you favorite dirt pedals into a compressor and hang a tone stack on the end of the cab sim and your done. Just my thought's,, YMMV.
Phil.
