TC Electronics - Chorus/Flanger [schematic]
- Dirk_Hendrik
I've dumped them ever here:
http://www.dirk-hendrik.com/temp/tcchorusA.jpg
- rocklander
- Has thanked: 1388 times
- Been thanked: 225 times
- Contact:
should the last "A" be a "B"?Dirk_Hendrik wrote:I've dumped them ever here:
yes, A & B, they're both on the serverrocklander wrote:should the last "A" be a "B"?Dirk_Hendrik wrote:I've dumped them ever here:
It's quite complex.Any layout/PCB o something like that?
- Bernardduur
Hmmmm, heard this pedal in action with Monte Montgomery last sunday.............
It has an awesome tone!
- Jarno
- my favorite amplifier: Accuphase E-308 (no money for it, yet)
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Busy building a modular synth (ssm2044 vcfs, preamps, ADSR's, VCO's, VCA's) - Location: Rosmalen, NL
- Has thanked: 3 times
- Been thanked: 9 times
I won one on eBay yesterday evening, can't wait till reaches me (will be a couple of days though, it's in Germany, and banktransactions take ages).
Hello there mr. Bernardduur! Fancy seeing you here, LOL
Regards,
Jarno.
Regards,
Jarno.
- Bernardduur
Jarno wrote:I won one on eBay yesterday evening, can't wait till reaches me (will be a couple of days though, it's in Germany, and banktransactions take ages).
Regards,
Jarno.
haha, I saw the name, I guessed the person........ right!
Welcome!
So really thanks a lot for the schematic.
Now i wanna try to remove the "strange" bypass system that use TC Elect for a true bypass, and remove also the stereo out and the external bypass...
I'm just now taking a serius look on the circuit: can you explain me what is the scheme on page A in the upper left corner?
The one with "s1-s2-s3" etc etc?
- fosnal1950
I would strongly advise not to remove the stereo out but try it " in stereo " this is the mode in which it really blossoms !
Alf
Alf
- Tube2stomp
The link here is not working any more, but I remember seeing the pics before and yup, it's a complex little mofo
Anyone has a "lite" version schematic for this thing?
I'm sure this pedal packs many extra sub circuits that can be shaved off (by someone who understands them of course) so the "audio" part will be revealed.
- celadine
Its a very elegant design. I don't understand it completely (especially the clock/BBD pin 4/input OTA connection), but I don't see any unecessary parts.Tube2stomp wrote: I'm sure this pedal packs many extra sub circuits that can be shaved off (by someone who understands them of course) so the "audio" part will be revealed.
- Whoismarykelly
I've been trying to figure out a little quirk with this pedal. When its in pitch modulation mode, the sound cuts out and then swells into the effect when you hit the switch to engage the effect. It makes me think the bypass switch is doing more than just bringing the circuit in and out of the path behind the input gain stage. Looking at the schematic I cant really see if thats the case. It looks like the bypass switch just lifts a ground connection. Any thoughts as to why this one mode would have an issue? The chorus mode has no perceivable issue like the pitch modulation mode has.
