DOD - 460 Mini-Chorus  [schematic]
Nyquist5
my favorite amplifier: The amps I build
Post by Nyquist5 »
Here they are:
http://nicosonic.free.fr/pedale/DOD460%20-1.jpg
http://nicosonic.free.fr/pedale/DOD460%20-2.jpg
http://nicosonic.free.fr/pedale/DOD460%20-3.jpg
http://nicosonic.free.fr/pedale/DOD460%20-4.jpg
Analogguru, let me know which values you need if you can't see them here, and while I have the pedal on the bench
Been thanked: 124 times
Thanks for the pictures, but still soome cap values missing. Since my time is short at the moment I will come back later to it.
Nyquist5
Post by Nyquist5 »
No worries!
Entrant_21
Post by Entrant_21 »
I love the yellow caps! I have a dod FX50 (original one) and its all yellow! :D both the shell and the circuit!
Has thanked: 232 times
Been thanked: 888 times
Bump for AG,
Just resurrected one (dead SAD512D). Let me know which values you still need. I tried to download the schem from your website but it seems gone.
lolbou
Has thanked: 308 times
Been thanked: 225 times
Post by lolbou »
Dirk_Hendrik wrote:I tried to download the schem from your website but it seems gone.
Indeed! Do you have the pots values? Thanks for the cap values though...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
Makes sense huh ;)
Speed: 500k reverse log
Depth 100k linear
lolbou
Post by lolbou »
Lovely! :D
azrael
Has thanked: 35 times
Been thanked: 88 times
Post by azrael »
Does anyone have the schematic for this? I was thinking of picking one up, but I want it at unity gain.
jefcon1
Post by jefcon1 »
I have one of these pedals and I would like to raise the circuit volume to unity gain (as was a previous poster). I'm skilled at soldering (4 years doing smt repair) and have a very basic understanding of components. I think I could swap the necessary components if I knew what they were. If this is not the right place to ask please forgive me for reanimating this thread. I used search first but could not find exactly what I was looking for.
azrael
Post by azrael »
^I was just planning to add a buffer on the output of the circuit and have it boost the volume a bit. :D
65greg
Post by 65greg »
My first post here...
I stumbled across this thread while trying to find a schematic for my DOD 460 mini chorus. I bought mine on eBay and it had a bad op-amp at the input - I replaced it and now it works pretty good but has the volume drop I see many people complain about.
Anyway, after looking at the pictures posted in the thread it appears my 460 is a little different than the ones shown. The layout is a little different and it has a resistor and one of the 10uF caps soldered to the other side of the board. It looks to me like a factory thing because of the same brand yellow cap with long leads.
I ordered a schematic from www.ronsound.com which hasn't come yet.
Hmm - as I write this I just noticed what looks like a possibly smoked resistor (upper left in the pic)
If anyone wants pictures of mine let me know ( i have nowhere to post them right now).
azrael
Post by azrael »
Sure, you can upload the pics using FSB's upload feature.
Let us know what you can make of the schematic! :)
mojah63
Has thanked: 40 times
Been thanked: 24 times
Post by mojah63 »
The 2nd half of the output tl022 could be used to raise the gain.. That's what I'm going to to do with mine. Raise the 47k resistor to 56K that should raise the gain 19%. Or use a trimmer to dial in what you need. Not sure if you'll have to bump up the 10K to keep the same frequency response. I'm reboxing mine to add a mix control and boss style power adapter.
Yeah I know it's an old thread but people do search..
electricalNoize
Post by electricalNoize »
Hello
I'm currently trying to repair a DOD 460 Mini Chorus and in my research I noticed that the SAD512d requires 10 volts minimum to operate properly and a max of 15 volts. But the printed information on the pedal suggest it only requires 9v. Does anyone know how this is possible?
I hooked up the pedal to an O-scope and the chip responded well, you see the phasing I turn up the depth on this video.
mictester
Has thanked: 32 times
Been thanked: 845 times
Post by mictester »
It was quite common for designers to misuse components in guitar effects circuits. The specification I have for the Reticon 512 says that it requires a "nominal" supply of 12V. It'll work down to (about) 7V, but it gets progressively noisier as the supply voltage reduces. The available clock rate also reduces. It's actually a poor circuit design, and looks like it's a wannabe CE2. The clock circuit is rather crude, and will give strange pulses into the clock input of the BBD, and the clock modulation will be an asymmetrical triangular wave.
electricalNoize
Thank you.
I am currently building an DC power supply for it. I just need to make sure its ok to build it for 12v.
electricalNoize
Could the drop in volume be attributed to the voltage?
The SAD512d datasheet says that it requires 15v to operate?
I'm currently trying to bring one of these back to life. I'm building a power supply for it and fixed a capacitor that was on backwards.
I still have not been able to get it to work.
Scruffie
Has thanked: 28 times
Been thanked: 170 times
Post by Scruffie »
No, to increase the output level, decrease the values of the 2 x 47ks going in to the output opamp inverting pin in equal increments.
