Boss - CS-2 Compressor Sustainer [schematic]
- MWichni
- Degoop Doctor
- my favorite amplifier: HI-WATT DR103
- Completed builds: Neo-Vibe, EH Big Muff Ram's Head, MXR Dynacomp, Demeter Compulator, Bk Butler Tube Driver, MXR Distortion +, Maxon OD880, MXR Phase 45, ProCo Rat, Colorsound Power Boost, BOSS CE-2, Rebote Delay 2.5, EH Electric Mistress, Fuzz Face, Tycobrahe Octavia, EH Pulsar. Custom made cabinet with 2x12" Celestion Vintage 30's.
- Has thanked: 7 times
- Been thanked: 57 times
Hi, is anybody able to do a pcb for CS-2 out of this?
http://www.godiksennet.com/images/sch/CS2PG2.jpg
http://www.bossarea.com/forum/uploaded/ ... latine.jpg
http://www.bossarea.com/forum/uploaded/ ... _unten.jpg
boss cs2 compressor sustainer.pdf- Boss - CS-2 Compressor Sustainer schematic
- (563.22 KiB) Downloaded 243 times
- andre
- my favorite amplifier: Hughes & Kettner Statesman Quad
- Completed builds: Dist + overdr.: Distortion+, BSIABII, Shaka III, Bluesbreaker, Box of Rock, Highway 89, DS-1, Proce Rat, Omnidrive, TS808, Bluemagic, Fulldrive 2, big muff
Delay: DM-2, Rebote 2.5, PT-80
Modulation: Ross Phaser, Small Clone, CE-2, Zombie chorus, FL-301, Easyvibe, Ultraflanger
Compr.: Dod280, Dynacomp
the rest: SG-1, Sparkleboost, BAJA CX-3 leslie simulator - Location: Netherlands
- Been thanked: 6 times
This one's so easy compared with the DC-2 I'm working on.
Why not give it a try yourself?
I can make one after I finished my DC-2, but I don't know when that will be.
- MWichni
- Degoop Doctor
Well because that I don't know photoshop well, don't know how to make it accurate dimensions, and others. Just don't know how to do that.
- andre
Well,... since I could not finish my DC-2, here's your CS-2 PCB:
If you print with 300dpi it should come out the right size which is 8.84 x 6 cm.
- puppiesonacid
look up how to etch pcb on you tube or pcb etching. its fairly easy.pf_fan wrote:Any tips how to create PCBs from such images? It's looks really cool. Nice job!
- MWichni
- Degoop Doctor
Wow, that was fast! Thank you very much. You are very kind.
Ouch, my bad. A little misunderstanding here...puppiesonacid wrote:look up how to etch pcb on you tube or pcb etching. its fairly easy.pf_fan wrote:Any tips how to create PCBs from such images? It's looks really cool. Nice job!
I'd like to know how he did that nice and clear PCB layout from the pic posted above?
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
pf_fan wrote:Ouch, my bad. A little misunderstanding here...puppiesonacid wrote:look up how to etch pcb on you tube or pcb etching. its fairly easy.pf_fan wrote:Any tips how to create PCBs from such images? It's looks really cool. Nice job!![]()
me too..............RESPECT
B.
- andre
This is how I do it:
I open the picture of the PCB in Photoshop.
I set the resolution to 300dpi.
Then I create a solderpad the same widht and hight as the solderpads on the picture.
Now I copy and place my new solderpad on top of all the solderpads of the same size on the picture.
I regularly hide the original picture and "merge all visible layers" and then unhide the original picture again.
Then I create the other solderpads like the rectangular ones on the CS-2 board, and place them one top of all the solderpads with the same shape.
No I use the "Line" tool to draw the outlines of all the coppertraces.
Again I hide the original picture and "merge all visible layers" and then unhide the original picture again.
After that I use the "Fill" tool to fill all the traces.
And again I hide the original picture and "merge all visible layers" and then unhide the original picture again.
Now I use the "Erase" tool to clear up some space between solderpads or traces that are too close to one and other.
If neccesary I do some small corrections.
After that I type some text using the "Type" tool.
Now I delete the layer that holds the original picture.
Then I mirror the image.
Finally I adjust the image size and voila... ready.
- MWichni
- Degoop Doctor
Thanks for the solution, next time I'll try to do my own pcb from image.
- MWichni
- Degoop Doctor
Here is a pcb for the conversion from original BA662 to BA6110:
https://img54.imageshack.us/my.php?imag ... ionov3.png
https://img54.imageshack.us/my.php?imag ... 110sq2.png
- MWichni
- Degoop Doctor
Here is described where to solder what, teha trannies could be 2N5087 and 2N5088:
https://img25.imageshack.us/img25/7209/ ... pisvq6.png
- MWichni
- Degoop Doctor
There is an error in your board:
https://img529.imageshack.us/my.php?ima ... ardbug.jpg
Here is without that bug:
https://img144.imageshack.us/img144/2342/cs2board.jpg
- andre
Yes, you're right.
When I was making this PCB, I saw there was only a small connection between the 2 solderpads.
So I told myself not to forget to make a connection between those pads.
But I did forget and separated them.
My bad. Sorry.
My bad. Sorry.
- MWichni
- Degoop Doctor
No problem, as you see I fixed it. Thank you very much again for your kindness and great work.
- MWichni
- Degoop Doctor
Here is a full component list for the BOSS CS-2 compressor:
https://img262.imageshack.us/my.php?ima ... ntlist.jpg
- MWichni
- Degoop Doctor
Hi, I'm not 100% sure about pin conversion. I've made a second layout for this (should be correct, but I didn't tested it yet) PCB dimensions are 4,75 x 2,5 cm. I'm not 100% sure about wire link from pin3 of BA6110 to pin4 of BA662A, please refer to the datasheets and boss schematics.
- Spazzmatazz
i've got an original cs-2 pcb board with all the components.
if anyone is interested
