Arion - SCH-1 Stereo Chorus [schematic]
- bacaruda
Hi all,
I recently rehoused an SCH-1 chorus, and made it true-bypass. It ticked terribly at first, so I shielded the input wires, shortened the pot wires, and decoupled power to the LFO. This solved the ticking problem.
Anyway, it worked perfectly for about 3 weeks, then suddenly started making noises again, only this time the ticks are more siren-like. Short "beo-whoops" over and over, in time with the LFO. At fast speeds it still sounds like a "tick-tick-tick . . ."
Unlike before, moving the PCB or wires around makes no difference in the noise. The chorus still sounds great, it just has the annoying noise problem.
I'm at a loss - I've tried everything I know to do with my limited knowledge/experience. Any ideas? I could really use some help.
Thank you.
Thank you.
- analogguru
Seems to be a grounding problem - ground loop/double earth.
- bacaruda
Thanks very much for the reply AG.
I didn't think it would be something so simple since it was working fine, then suddenly started freaking out, but I will certainly try hunting down ground loops tonight. I could have easily made a mistake with the shielded wire.
Thanks again.
Sorry, I posted this is the wrong section. Feel free to move it mods.
Thanks again.
Why did you convert to true bypass? One can change one resistor (R4, from 470k to 1M) and swap the input buffer transistor Q1 for a JFET (i.e. from a C1815/2SC1825 to a MPF102, J201, 2SK117, etc). One has to swap the Drain and Source pins around on the JFET though (i.e. Drain=Collector, Source=Emitter, Gate=Base). It has much less tone suckage.
- bacaruda
Grolschie - because I never thought of it . . . and also because I would need clear directions like the ones you just gave me! I did figure out (from Clay's schem) how to bypass the FET switching to make it true-bypass, but I'm still a beginner at this electronics stuff. I'm learning, though . . . slowly!
That is a really great idea though, and if I ever get another SCH-1, I will definitely try it. Rehousing this one has been a major headache, but I love how it sounds.
If you have quite a few pedals on your board, then a decent buffered bypass will serve you well. True bypass is great when only using a couple of pedals. I too am a beginner. I now look at the schematics for my pedals and try to see if there are any components that can be upgraded. Buffers and ICs are a good place to start. I live near Bajaman , and he has been an excellent tutor for me.
- bacaruda
Thanks Grolschie. I usually just bring a good boost or two, a delay, and sometimes the SCH-1, with 20-25 feet total cable into my homebrew 5E3. With this setup at least, I always prefer not having any buffered pedals in the loop (at least the ones I've tried). I put the only buffered pedal I bring, a TU2, on a switch.
AG - I found a ground loop, and what do you know, it fixed the problem!
Thanks guys.
Thanks guys.
- bacaruda
okay . . . well the "ticking" has returned, but only when I'm using the Arion with other pedals on the same 1Spot daisy chain. Otherwise, it works just fine. I assume it's a grounding problem, but I've been over the pedal a thousand times and can't find any loops; am I missing something obvious? I have been known to do that from time to time.
I'm playing out tonight, and really want to bring it - but I'll only have about 2 hours to work on it after I get off work. I would be grateful for any suggestions. btw, there is no room in the enclosure for a battery.
Thanks.
Thanks.
- pz
well, this looks like the ticking is coupled to another pedals via the power and ground line.
Solutions:
- use separate power supply for this pedal, when it's not possible (pedalboard too small etc):
- use separate power cable for this pedal, split the cables just after the PS, although it may not help to solve the problem. When this is also impossible:
- try to power Arion as the first pedal in daisy chain
hope that helps
regards
pz
Solutions:
hope that helps
regards
pz
- bacaruda
pz - thanks for your reply. I tried powering it first in the daisy chain, but it didn't help much. I think I'm going to try making a standard power filter between the DC jack and the Arion, and if that doesn't work - then I'll just have to use a separate power supply, like you said.
I just think I'm missing something because I didn't have this problem before modifying it. Thanks again.
- polifemo
Those that have played an Arion SCH-1 chorus knows that there is a volume boost when the effect is engaged.
This has never been a problem for me personally, but a friend of mine wants his chorus to be modified for "unity gain".
Any ideas what to do?
- analogguru
If this is true, then you can try to look out for R58 (51k) and reduce it to a lower value or install a trim-poti there.
It is a bit complicated since it is not clearwhich and how much volume increase occurs.
Thanx grolshie, I took your word for it and changed R4 and Q1 to a 2SK117... And now there's no need for true bypass. Sounds great!!!grolschie wrote: One can change one resistor (R4, from 470k to 1M) and swap the input buffer transistor Q1 for a JFET (i.e. from a C1815/2SC1825 to a MPF102, J201, 2SK117, etc). One has to swap the Drain and Source pins around on the JFET though (i.e. Drain=Collector, Source=Emitter, Gate=Base). It has much less tone suckage.
Although mine has improved, recently I was sure that I could hear the effect slightly when the pedal was off, when I was playing through headphones. So some might still need true bypass on this pedal...
- moltenmetalburn
Does anyone have a PCB layout or want to contribute one for this one? I had one as a kid and loved it, it disappeared after many years and Ive never been happy with a chorus since.
The thought of being able to make a clone of the circuit out of top notch parts and true bypass gets me almost giddy. I am surprised no one is selling a clone of this one that I know of.
schematic here:
https://img.photobucket.com/albums/v474 ... Chorus.gif
schematic here:
- destro
That was the first pedal I ever owned. Bought for 20 bucks at a pawn shop over ten years ago. I always thought that the tone control was rad. Unfortunately it fell to pieces over the years and before I got into diy it died and I tossed it. I've never rean across a clone project, but please post back if you find one!
- Dirk_Hendrik
Chorusses are too difficult for most wannabee boohteekers. For setting them up they would need an ocilloscope and far worse, knowledge.! More than 15 components . Therefore they stick to Fuzzes and treble boosters.moltenmetalburn wrote:I am surprised no one is selling a clone of this one that I know of.
