MXR - Micro Chorus [schematic]
- GodSaveMetal
Please man a layout with the mod using the MN3007 o the MN3207!!!!! thanks for your efford your are great!!!
- Fender3D
Looking at the Vbias vs Vdd graphic, you have an almost linear curve, meaning that when Vdd decreases, Vbias should decrease in a similar manner thus avoiding distortion rising (in an acceptable way) when DC supply gets lower and lower.Dirk_Hendrik wrote:...
2) In the current application the supply voltage for the BBD and the BBD bias is the same as the overall supply voltage. This means that when this voltage rises or lowers suddenly your BBD output signal can start to distort or fall away since the bias voltage changes as well. Add a resistor and a 8v2 zener and be on the safe side.
It's different with phasers where the zener will provide a proper FET biasing.
I used a different approach to achieve Vbias and Vdd in my MXR flanger replica:
- Dirk_Hendrik
Unfortunately it doesn't work that way.... which I found out after spending half an afternoon trying to find out why my box did work on the bench (delayed signal) and did not in the living room (no delayed signal). Bench supply was set at 9 volts. Living room was a "standard" Ibanez adapter which when I finally figuered out the problem happened to be a 10 volts type used for tubekings.
- Dirk_Hendrik
Fender3D wrote:I used a different approach to achieve Vbias and Vdd in my MXR flanger replica:
Charming piece of economy use of that trimmer!
- DimebuGG
The layout's is as per schematic (the corrected one) by mictester's. I'm pretty sure there are no mistakes assuming the schematic is working.jbgron wrote:I just built Dime's layout and it doesn't work, the signal just passes straight through unaffected. I've tweaked the trimpots and audio probed to no avail. Has anyone successfully built Dime's layout?
- GodSaveMetal
Please were I found taht schem or PCB it´s any???Fender3D wrote:Just updated MXR micro chorus' .jpg and .pdf schematic files.
Corrected R8 value (was 2K7)
- GodSaveMetal
I got it!!! but how to make a doubler withut the MAX1044 or the ICL3660 or other!!! there are nothing of these in my country!!! please another form to do a conversion for 9V to 18V???
- Fender3D
the MXR micro chorus works with 9V.
I don't know if the MN3007 adaption works with 9V, my MXR flanger wouldn't work properly with 9V, so I guess an MN3207 might be a better choice...
Doubling voltages with MAXs or ICLs, always leads to boring noises here and there, whether the battery isn't an option, you'd better build a proper power supply or adapt the schematic for MN3207.
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
odgeuk wrote:Hi guys
I notice that MXR still sell a Micro Chorus pedal. What are they using if SAD512D chips are no longer in production?
My guess is MN3207
- GodSaveMetal
Please you have the link????Barcode wrote:You can also use analogguru's schematic for voltage doubling with a 555 timer chip, a common part.
- sinner
Here or http://www.justfuckinggoogleit.com/GodSaveMetal wrote:Please you have the link????Barcode wrote:You can also use analogguru's schematic for voltage doubling with a 555 timer chip, a common part.
Has anybody built one from the PCB layout?
Thanks,
CR
Thanks,
CR
I read that the 80's Micro-Chorus used an R5106.sinner wrote:odgeuk wrote:Hi guys
My guess is MN3207
For the Micro-Flanger, MXR substituted the SAD512 with what they described as a "512-stage delay line similar to the MN3204".
- my favorite amplifier: Orange
- Contact:
The NEW micro chorus (Reissue) uses a V3204D. This is a 512 BBD stages made in china for Dunlop. It is a copy of the old MN3204.
ivan.
ivan.
Question, the trouble seems to be in the timing circuit, would it work better if you used a MN3101 timing chip like the CE2 clone, instead of the discrete components?
Would that change the sound?
CR
CR
I just received a brand new reissue Micro Flanger;
I also have an original, which has the Reticon 5106 IIRC (though I have seen them with the SAD 512 as well), but the reissue has the V3204D chip.
Footswitch is an Alpha DPDT by the way, and I've read a few times that new MXR pedals that say 'True Hardwire Bypass' have in fact a true bypass switching method, using the Millenium bypass for the LED.
In the reissue Micro Flanger I also spotted a TI 4069UBM.
