snarling dogs - black bawls
devastator
Been thanked: 22 times
Post by devastator »
I tried to draw the schematic, seems to be a varation of classic inductor wah (crybaby/vox) with some change (cap values, resistor). The sound is deeper and softer than other pedal.the range is also bigger compared to other wah pedals (a little bit like the colorsound's pedal I guess). The center frequency is lower (two cap in // where in Dunlop circuit a 10n cap is present) .
The metalic stuff close to the footswitch is the.....inductor ( :shock: ) (I haven't tool to know its value)
The boost section is a bipolar transistor with the pot. (with a big cap on the wipper) placed in // with the emetter's resistor (that's not really a lood boost , by the way )
mundry
Been thanked: 8 times
Post by mundry »
mundry wrote:i draw the schematic
If I could seee it....
mundry
Post by mundry »
here is it
there's something strange in this schematic:parallel C9-C10 and R6-R7 but that was their placement.
E1-E2 are the connections to inductor..i don't know the value of the inductor...i think is a classic 500mH
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
Hey mundry,
I guess you reversed C and E in your transistors CAD models...
(drawing only, 'cause schematics seems ok regarding B-C-E labeling...)
mundry
Post by mundry »
Is because i didn't find the exact model on the eagle CAD library.... so i signed E-C-B on the schematic by reading the datasheet (but with a generic symbol)
Thanks for the schematic. I invested three minutes with the windows program "paint" to change E and C and add the missing resistor R4. Below is the result.
The parallel R6 and R7 appear to be a factory routing mistake. R6 should be in parallel with E1 and E2. This can be corrected easyly with a stanley knife at the pcb. The value of R1 is also suspiciously high but also used in the "Wonder-Wah". In the "Mold Spore" it has the (correct) value of 68k.
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
Speaking of the Mold Spore, does anybody have a schematic of that nasty thing?
Skyline FX 2013
mundry
Post by mundry »
did i missed that resistor (r4)? :shock:
gotta check again :slap: :scratch: , thanks for the revision Analogguru! :thumbsup
