EHX - Big Muff Pi 1977 & 1978 version [schematic]
- bumblebee
i traced this from photos of an original,its the original PCB layout.
its not verified,i dont need to build it as i own one.(1322)
it probably wont fit in an enclosure much smaller than a bmp box tho.
i was gonna put it in an old bmp enclosure i have but then i bought the ic version and i dont need to anymore.
edit:this should have actually gone in the modern section as it wasnt made till 77 iirc.
you can buy the PCB mount pots from mouser and new sensor.
I so dislike the modern digital world that I need to use semi-digital effects to emulate the analog world of cassette, VHS, and vinyl.
- bajaman
- Has thanked: 595 times
- Been thanked: 2056 times
Thanks for sharing bumblebee
- Bernardduur
I have on in my Deluxe Muff; it is pretty bad
- bumblebee
i love the ic muff,i have a 1978 1322 version and its super nice.
- Dirk_Hendrik
I guess that so far I've played all Muff versions, and quite some clones based on, that were made. All practiced what they preaced, pure guitar porn, in variations form sweet anal to brutal hardcore... that's the IC one...indeed.
But bottom line is.
The never let me down.
oh my... did I really write that!??
But bottom line is.
- bumblebee
never thought of the ic muff as brutal anal before,i'll never look at it the same again thanks to you.
- Dirk_Hendrik
- bumblebee
there was an error in the layout,its been corrected. if anyone saved it you might wana save the updated version.
- seniorLoco
If your tracing is correct, then this schemo has error
- analogguru
I can´t understand why people are still using old and wrong schematics when correct schematics are available since years:
http://analogguru.an.ohost.de/193/schem ... _OP-77.gif
http://analogguru.an.ohost.de/193/schem ... _OP-78.gif
- bumblebee
this is old and id go with AG's schem if i was you.seniorLoco wrote:If your tracing is correct, then this schemo has error
the tracing is correct,ive amended a error it had and that was more due to a lack in concentration while drawing more than anything else.
ive compared it to the high quality photos i have of the 1322 PCB and everything is spot on. i havent trace thru it with a schematic as theres no need to imo.
- ShortScaleMike
I just did this for an IC Muff, it's unverified but may help anyone wanting to build one:
As always, build reports and corrections are welcome
- devastator
- analogguru
I think you mean these ones:
which can be found here (beside other schematics):
- devastator
Yes I found them on your website in making google research. Thanks !
looks interesting, sounds similar to the original one (transistor version) or really different ?
the filter with second AOP, what's its frequency cut ?
Don't know what year this is but should be one of the old ones.
This one is leaving this week, if anybody needs some details ask quick.
Snail
Snail
- dt 024.jpg (49.87 KiB) Viewed 6886 times
- dt 023.jpg (54.85 KiB) Viewed 6886 times
- dt 022.jpg (55.41 KiB) Viewed 6886 times
- dt 019.jpg (66.89 KiB) Viewed 6886 times
- dt 018.jpg (48.88 KiB) Viewed 6886 times
- dt 016.jpg (31.92 KiB) Viewed 6886 times
- lolbou
Could you please give the codes on the potentiometers? These would help to date.snail wrote:Don't know what year this is but should be one of the old ones.
Thanks for sharing anyway...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- theehman
snail wrote:Sure!
They read 2 sets of numbers
Sustain:
ZA2124
1377805
Tone:
ZA2124
1377805
Volume:
XM2184
1377742
snail
That dates it to 1978.
Ron Neely II
fx schematics and repairs
