"Cheap trick" to smooth the tone of a TC electronic Tube Pilot...
freefrog
Post by freefrog »
.. the tittle of this thread being an attempt to play with words, although English is not my mother tongue. :P
I've already posted the explanations below in some long tedious posts or threads in other forums... But it should make more sense here. I'll just keep it relatively short for a first topic. :-)
The Tube Pilot is a cheap tube overdrive, apparently "inspired by" Butler / Chandler / Tube works Tube Drivers.
Problem: the Tube Pilot doesn't host any tone control nor tone correction for the upper part of the spectrum. Its response is flat in the high range, making it harsh through most amps.
My cheap and easy solution: adding a small cap between the center lug of the volume pot and its ground lug... It can be done from the bottom of the PCB, without unscrewing anything else than the housing.
The optimal value depends on other parms: amp used, tube mounted in the TP...
I've got good results with 2,2nF, 3,3 nF or 4,7nF capacitors. A TP with a 12AY7 and a 4.7nF cap has a frequency response and THD close to those of a "real Tube Driver", IME.
I use two TP's modified like that for more than a year now and among other tube pedals, most often much more expensive. IMHO, they're up to the task since I've fitted them with smoothing caps.
FWIW - and shared just for the pleasure to share, whatever it's worth. :)
