Baja Presence and Resonance 091118  [documentation]
temol
Has thanked: 23 times
Been thanked: 213 times
Post by temol »
Hi bajaman.
Where did you find C100k 9mm pot?
T.
Has thanked: 596 times
Been thanked: 2061 times
temol wrote:Hi bajaman.
T.
I didn't - I just used B100k :wink:
caspercody
Has thanked: 34 times
Been thanked: 48 times
Post by caspercody »
Thanks for this, I made this and it works great!
Is there anyway I can add a trimmer to adjust volume? It seems to boost level a little
The easiest option is to change the 100k resistor on the output to a 100k pot or preset and connect the 1k resistor to the wiper of the pot.
caspercody
Thanks bajaman, that volume idea works great!
jhergonz
my favorite amplifier: Mesa Boogie and Soldano SLO100
Has thanked: 112 times
Been thanked: 21 times
Post by jhergonz »
in case any one who wanted to hear Baja Presence and Resonance before they build it, here is a short demo that i uploaded in my Facebook account.
jhergonz
Post by jhergonz »
Just one question to understand the circuit.
At first I used non polar capacitor at C3(10uf) because I didn't read the note at the end of Temol's pdf, and the circuit didn't work.
Change it for polarized capacitors, and it worked properly.
Why does polarized capacitor makes it work and not unpolarized capacitor? Is it some sort of Phase issue?
Ichabod_Crane
Has thanked: 84 times
Been thanked: 36 times
Post by Ichabod_Crane »
jhergonz wrote: 28 Feb 2021, 03:31 in case any one who wanted to hear Baja Presence and Resonance before they build it, here is a short demo that i uploaded in my Facebook account.
I like your Khaos Distortion. Do you share the schematic? Or at least you can tell us if it's based on some other circuit? If you can't share it never mind, I understand. :thumbsup
Thanks for the demo!
jhergonz
Post by jhergonz »
It is based on Amptweaker Tight Rock with some Modifications. That is all I can say for now. Thank you for understanding. 😁
Ichabod_Crane
I built a Tight Metal. I know there's around the schematic of the Tight Rock and I thought to build one day a kind of version between those two pedals: a sort of Tight metal but not so heavy and more rock than metal. :D
Your pedal sounds great! :applause:
jhergonz
Post by jhergonz »
Ichabod_Crane wrote: 01 Mar 2021, 08:45 I built a Tight Metal. I know there's around the schematic of the Tight Rock and I thought to build one day a kind of version between those two pedals: a sort of Tight metal but not so heavy and more rock than metal. :D
Thank you for the compliment.
andersrain
Post by andersrain »
hi, this is amazing bajaman, it possible to add a knob like volume to simulate a power amp section?
jhergonz
Post by jhergonz »
andersrain wrote: 06 Jul 2021, 18:07 hi, this is amazing bajaman, it possible to add a knob like volume to simulate a power amp section?
you could put the volume control after the circuit like any other volume control.
andersrain
jhergonz wrote: 07 Jul 2021, 06:40 you could put the volume control after the circuit like any other volume control.
thanks im new to this, question about volumne knob does not interfere with the sound, rigth?
jhergonz
Post by jhergonz »
andersrain wrote: 08 Jul 2021, 00:21
if you mean tone, i believe it won't interfere with it
andersrain
it is possible to make this modification?
dxjxrose
Post by dxjxrose »
Question I run a line 6 helix into a matrix Poweramp because I have a bad back now...... Would this give me a more tube like feel? Even with a solid state amp?
herdiss
Post by herdiss »
My version of the Baja Presence and Resonance:
Optical
Has thanked: 16 times
Post by Optical »
andersrain wrote: 13 Jul 2021, 17:51 it is possible to make this modification?
These tubes should have a flat frequency response from any given circuit.
That switch might be a as simple as altering the clean headroom - a selection of clipping diodes perhaps.
andersrain
thanks to @bajaman for this amazing pedal!
