BAJA Kiwi Wah Wah pedal
Hi folks
here's a new wah I designed and built recently.
it uses a Whipple inductor (although other inductors should work reasonably well :wink: ).
P3 and P2 on the layout refer to the potentiometer terminals (P1 is connected to ground :wink: )
MPSA42 was chosen for low hfe - a 2N3904 will work well here too :wink: .
I used 2M7 resistors in this build instead of the 2M2 specified on the overlay picture - not a big difference - they are only there as fet biasing :) .
The wah shell was purchased from Smallbear electronics a few years ago.
Basically - the design is a standard wah wah with jfet buffered input and output BUT with true bypass.
The footswitch is wired so that the input to the wah input buffer is grounded when the effect is bypassed - this ensures low noise switching characteristics.
Enough talk - the drawings are 600dpi :secret:
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Thanks for sharing bajaman!
Any explanations about the choice of both true bypass and input buffer? Though I get the output buffer right, I do :scratch: for the input one actually...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
nice, baja!
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
I think the input buffer is there for a more suitable input impedance for crazy vintage effects that don't play nice with Wahs.. like (esp.) the Fuzz Face..
Right ?
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
The Whipple is good! :thumbsup
Image Ken
atreidesheir
Has thanked: 441 times
Been thanked: 43 times
Post by atreidesheir »
How does this sound compare to the wizard wah you provided?
Generally.
And thanks for another "must build" project.
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
Nice.......I love how you make PCB.......what software did you use???
Boris
CorelDraw X4 :wink: - but the only problem is it does not generate gerber files - okay for home made etched boards though :)
B Tremblay
Been thanked: 14 times
Post by B Tremblay »
Will you be sharing the schematic?
B Tremblay
runoffgroove.com
yes :wink:
I just have to draw it up and make it pretty, but essentially it is just a standard Cry Baby wah with a higher gain first stage and buffered jfet input and output.
ebuprofen
Completed builds: http://ebupro.blogspot.com/
Been thanked: 12 times
Post by ebuprofen »
Nice build, what about sound samples? :D
binog15
Post by binog15 »
Excuse my poor english.
I rode. there was a problem because when the potentiometer is in course of approximately 75%, a glitch occurs.
Anyone have any idea what could be?
thanks
the3secondrule
Completed builds: GGG Phase45
Fuzz Factory Clone
Shin Ei Companion Fuzz
EHX LPB
Fuzz Face
Zvex Machine
GGG Green Ringer
woolly mammoth
SHO
Microamp
Noise swash
Phaseur Fleur
Catalinbread SVT
valvecaster
CE2 Chorus
Aquapuss
Has thanked: 24 times
Been thanked: 13 times
Post by the3secondrule »
Hi Steve,
I was wondering if there was any way I could get a couple of PCB's etched for this, as I don't have the ability / equipment, but I have a couple of empty crybaby shells that are crying out to be used. and I'm definately into the idea of the in + output buffers...
Jeremy
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
