p.s. IC10 is mislabeled ATM
Work so far:
Well... we did it with the Aqua Puss, we can do it with this... I'm guessing that's why Madbean was asking after MN3205s in another thread... so i'm looking forward to this as that's something I always wanted to build, a 3205 DMM (Just cause I can't find the 3005s)Greenmachine wrote:Awesome.
All that's left to do now is sacrifice a first-born child to Circuitous, the god of electronics, so that we'll have MN3005's rain upon our grateful heads.
I've adjusted my trimpots "by ear"... if you have a single BBD circuit, the work is pretty easy, but with a double BBD I've used the audio probe for a correct bias-setting... I've connected a beep signal in the INPUT, and I've setted the BIAS trimpots for having the best wet signal possible from each BBD.roseblood11 wrote: I think the biggest problem for most builders will be to set the trimpots correctly. I never managed to do that just "by ear".
I know that there´s an instruction somewhere on the web that explains how to do it with an oscilloscope, but not many people have one...
The only problem I had was giving up on the layoutDrNomis wrote:Would it be possible to build the Deluxe Memory Man on Vero/Stripboard?,or would there be problems getting the circuit to function properly?,
just wondering if it is feasible at all...
Yes, I agree. Don't take my little attempt at humor as a lack of interest. I'll be hot on the heels of this one too!Scruffie wrote:Well... we did it with the Aqua Puss, we can do it with this... I'm guessing that's why Madbean was asking after MN3205s in another thread... so i'm looking forward to this as that's something I always wanted to build, a 3205 DMM (Just cause I can't find the 3005s)Greenmachine wrote:Awesome.
madbean wrote: I had to give up on the idea of board mounted pots, unfortunately. Here's a preview...I still have to make sure the schem is
I think CPM made quite a bit of head way with his conversion, i'll have to look for the thread again unless he chimes in here, that should hopefully take away some of the work for converting it.I'm open to a v3205 conversion down the line if this works out. The power requirements are different, so it will take some finagling. But, I don't see any reason why it couldn't be made to work.
That'd make a sweet etch your own project as a more complete package Echo Base, looking forward to that one too.I'm also thinking of a conversion to PT2399 with 2 chips of them in series to get around 800ms of usable delay. It won't be a DMM, obviously, but maybe it could get reasonably close. And, that would require no calibration at all
The CoolAudio is not interchangeable with the MN3005. It's possible that the existing layout can be reworked for it, though. The v3205 needs about 5v to operate, whereas the DMM powers the MN3005 at -15v. I think the best way to go is change the voltage to 15-18v for all the other ICs and 5v for the BBD. Plus, the pinout is different on the v3205 so that has to be changed, too.andersom wrote:Really nice stuff, are you gonna try to use the coolaudiochip?
