Looks great, but I made it by my self. I'm Express PCB-holic!k1rkyd wrote:Have you tried my PCB layout??
KLON BUFFER VERO
hey man just found some time to check the pcb and i have a few questions...
is this a mirror image or i should do a mirror print? if this is ready to print then there is a wrong cause the marked corner of the opamp it cant fit there (dot in c1 side) but can fit the other way (dot to the power supply) i dont know its gonna work so i'm gonna wait for you to check it.
thanks again
thanks again
- k1rkyd
Hey buddy I'm on my phone so I can't check the PDF version but the first component layout Is correct and the pc board is the mirror image of that without the components!! Does that sound right to you??harrisxr650 wrote:hey man just found some time to check the pcb and i have a few questions...
thanks again
I stepped up on the platform; a man gave me the news; he said "You must be joking son, where did you get those shoes?"
yeap its right... but i think the orientation of the opamp is wrong its like i have to solder it in the trace side not the component side
- k1rkyd
Hey man just double checked it and if you iron the ready to print version from the PDF on the second page onto the copper cladding, when you flip it back over to the component side, the orientation of the ic will then be correct!! Does that seem right to you?harrisxr650 wrote:yeap its right... but i think the orientation of the opamp is wrong its like i have to solder it in the trace side not the component side
first of all thanks for replying mate layout is fine i guess here is a pic to see
https://img824.imageshack.us/i/opamp.jpg/
the black 'x' points the opamp marked side and its the way it should be placed right? ( according to components schematic) if i turn the board on the component side the opamp marked side goes to the red 'x' and i'm not sure if its correct
- k1rkyd
Hey buddy no problemharrisxr650 wrote:first of all thanks for replying mate layout is fine i guess here is a pic to see
There seems to be a problem..
I have placed a mirror infront of the PDF ready to transfer (the large board at the top on the left) and it seems fine!
I'm not sure whether you have reversed the ready to transfer board and so it's come out back to front??
Where about are you based? Are you in the UK? If so, i will make you a board and send it??
Regards,
K1RKYD
nah its ok... i printed the 2nd page as you instructed. tha means my print is reversed? if so i can still reverse it and print it again. no big deal i guess
- k1rkyd
I hope all goes well.harrisxr650 wrote:nah its ok... i printed the 2nd page as you instructed. tha means my print is reversed? if so i can still reverse it and print it again. no big deal i guess
I just made the vero layout and put it on a DPDT switch with this type of wiring
So i can add it if i want to.
Below is a photo of the distortion pedal with the buffer switch in view!
Works really well
Speak soon man,
K1RKYD
man that buffer rocks badly...after almost one year and i cant even think playing without it. there is a huge different if i dont use it ( tone sacking big time). my rig is the same yet only i moved my wah after the fuzz's and before the modulation pedals. i use the same 9v battery i put a year ago and still working. i wonder if i can make an a/b box (to use use for my lame tuner) and put it inside it. gone look for wiring over the internet. if you got anything i'll gladly accept it . again man this little circuit rocked my world. thanks
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
- rizibiz
Ok I did another one because I don't like standing resistors - thanks IvIark for spoiling me
And to ground the inputs of the unused half of the TL072 (and I don't have TL071's on hand)
Red is +9V, Black is ground, Yellow is input, Green is output
- rizibiz
I've just verified my own layout.rizibiz wrote:Ok I did another one because I don't like standing resistors - thanks IvIark for spoiling me
- soulsonic
Hey, why are you guys wasting half a TL072? You could just use a TL071 and have the same circuit without the wasted extra opamp. You should consider trying it with an LF411 as well. It's a similar JFET input type, but has better overall spec.
- rizibiz
Yes indeed you are right. Let me explain: since a lot of pedals use TL072 dual opamps for buffers, etc. I have a huge stockpile on them. I tend to use this IC for tube screamer derivative circuits too. I don't keep single opamps in my parts box as I rarely use them. I don't shop for TL071 because in my country they ask the very same amount of money for the TL072. So I just buy TL072s in bulk and if the application needs only one op-amp I waste the other half of the dual op-amp package.soulsonic wrote:Hey, why are you guys wasting half a TL072? You could just use a TL071 and have the same circuit without the wasted extra opamp. You should consider trying it with an LF411 as well. It's a similar JFET input type, but has better overall spec.
Anyways, thanks for the LF411 reference I'll check it out.
- soulsonic
I use singles alot. LM301, NE5534, LF411, CA3130 & 3140, 741... these are all very useful to have around. Most singles share the same pinout so you can swap 'em just like the duals.
LF412 is the dual version of the LF411, same pinout as all the other duals.
- rizibiz
Here LF412 costs 3 times a TL072. Nevertheless I'll buy one just to compare if I can hear a difference.soulsonic wrote:I use singles alot. LM301, NE5534, LF411, CA3130 & 3140, 741... these are all very useful to have around. Most singles share the same pinout so you can swap 'em just like the duals.
I still don't get the advantage of using singles since they are not cheaper or smaller. Speaking of my own layouts of course.
It's a different story when sourcing parts for an existing PCB or layout.
