Fuzz Factory NPN AC127 - PCB n Layout Inside
Original effect designs complete with verified schematics, layouts and instructions. All project were freely contributed by members and cannot be used for commercial purposes without consent of the respective owners of the copyright.
tiococo
Post by tiococo »
Guys.
I have at my disposal a lot of AC127s so I decided to make a negative ground version of the fuzz factory
Here is the schematic
Please check if everything is okay and I hadn't made any mistakes...
fuzzfactory pcb.pdf
(13.81 KiB) Downloaded 227 times
fuzzfactory layout.pdf
(27.65 KiB) Downloaded 255 times
my favorite amplifier
Self-Built Valve Amp Head :)
Completed builds
Dallas Arbiter Fuzz Face,Tone Bender Professional Mk 3,Tone Bender 3-Knob,Baja BK Butler Tube Driver,Baja Real Tube Overdrive,Roger Mayer Octavia,EH Soul Preacher,Tech 21 XXL Distortion,MFOS Weird Sound Generator.
Location
Darwin,Northern Territory Australia
Has thanked: 99 times
Been thanked: 267 times
Post by DrNomis »
I just had a look at the schematic, and it appears to be all good.... :D
Traynor YBA-III, Fender Super Six
Has thanked: 141 times
Been thanked: 137 times
does the FF have that power filtering cap? seems to me, that would quell any oscillations.
adielricci
Completed builds
Tube Screamer, Tube sound Fuzz, Fuzz Face, Rebote Delay, OCD, Micro Amp, Distortion+, Super Hard-On, Dyna Comp, X-Grinder, RVIII Fuzz, WH10 Wah, Ultra Fuzz, RX+, and some others.
Been thanked: 8 times
Post by adielricci »
The output pot has to be in series with R6, or you have to add another 5K1 resistor in series with it and capture the output from their junction, maybe with a 100K pot.
adielricci
Completed builds
RnFR wrote:does the FF have that power filtering cap? seems to me, that would quell any oscillations.
In that place, there is no problem, and I would even add another 100n cap in parallel with it, to kill any high frequency transients.
Completed builds
Location
Post by DrNomis »
I just noticed something, there should be a coupling cap between the output control pot and the rest of the circuit, the cap can be anything from 10nF to 100nF, also there should be a 470 Ohm resistor going from the 5.1K collector resistor (R6) of Q3 to +V..... :D
ckyvick
Post by ckyvick »
How would it sound? Wouldn't you want to make it positive ground like the reverse fuzz factories?
http://t1.gstatic.com/images?q=tbn:ANd9 ... DCBS-g&t=1
tiococo
Post by tiococo »
Guys. I Have updated the schem.
One is the the OEM configuration
Here
And here is the normal Fuzz Face configuration
(A Npn Fuzz Face with a buffer and pots instead od resistors)
Ok, as I see, the OEM Factory doesn't have the 470 Ohm resistor. Thats no problem because the pot acts as a voltage divider when the pot is not maxed. But what happens when it's maxed? The center wiper goes to 9v, that DC blocked by the cap will carry audio?
The second configuration seems more logical (and familiar) to me. But I want to preserve the circuit as original as I can.
opinions?
Completed builds
Location
Post by DrNomis »
tiococo wrote:Guys. I Have updated the schem.
Here
opinions?
The OEM Factory configuration will work if you wire up the volume control pot so that when it's maxxed out( turned fully clockwize), the wiper is at the junction of the 5.1K (R6) resistor and the volume control.... :D
tiococo
Post by tiococo »
that's what I thought :D
tiococo
Post by tiococo »
Corrected.
Done.
I'll verify the pcb and post what happens later.
Regards!
(14.05 KiB) Downloaded 177 times
fuzzfactory pcb.pdf
(14.35 KiB) Downloaded 147 times
Loss1234
Post by Loss1234 »
HMMM...I built this as per the schematic (both ways) and with a variety of NPN's I can not for the life of me make it oscillate like the PNP version I have built (with a variety of transistors)
when the OP built this, did it oscillate properly?
thanks
Scruffie
Whatever sounds best at the time
Has thanked: 25 times
Been thanked: 130 times
Post by Scruffie »
Loss1234 wrote:HMMM...I built this as per the schematic (both ways) and with a variety of NPN's I can not for the life of me make it oscillate like the PNP version I have built (with a variety of transistors)
thanks
Yeah the Fuzz Factory oscillates because it's a positive ground circuit reversed (positive ground circuits don't work quite right reversed alot of the time)... if you fix it to negative ground I can see why it wouldn't.
soggybag
Completed builds
Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
Has thanked: 19 times
Post by soggybag »
Has anyone built this? I was just thinking about trying to do a NPN Fuzz Factory and low and behold google reveals this thread.
tiococo
Post by tiococo »
I built 3 boxes with this layout. So its verified
