Ersatz Verben - PT2399 pseudo reverb
culturejam
Has thanked: 433 times
Been thanked: 563 times
Post by culturejam »
earthtonesaudio wrote:If you take the LED outside the feedback loop (i.e. output of the op-amp -> resistor -> LED -> ground) it will work.
Nice. I actually thought about this after I posted. :thumbsup :hmmm:
briggs
Has thanked: 27 times
Been thanked: 128 times
Post by briggs »
I once designed a sort of overdrive/compressor using that technique. It works quite well if you find the right type of LEDs...
I am Klon.
culturejam
I was thinking that typical chap diffused LEDs usually have the lowest forward voltage and would work best. I'll have to give it a try tonight or over the next few days.
briggs
Post by briggs »
^^ Diffused low current red LEDs are the ones I went for, with a fairly reactive LDR for the gain reduction in the opamp...
Why not use a 386 chip instead of the bazz fuzz? They provide enough current to light the LDR well, with a variable resistor in series with the LEDs you'll get some control over the depth of the pitch bending and levels of the clipping...
I am Klon.
culturejam
briggs wrote:Why not use a 386 chip instead of the bazz fuzz?
I was trying to avoid ripping off the Clarinot so directly. :lol:
briggs
Post by briggs »
oooopps, I didn't realise that used a 386! I need to check these things before I open my gob :slap:
I am Klon.
newly
Post by newly »
rocklander wrote:had a quick crack (unverified) at a layout too (hope that's okay).. also 1590a.. and it's off the first schematic..
layout
pcb
expresspcb file
ersatz-verben-pt2399-reverb-1590a.zip
Is this layout verified? My build doesn't produce verb sound...well just to confirm before i started my trouble shooting.
rocklander
Has thanked: 1406 times
Been thanked: 231 times
Post by rocklander »
not by me... (hence the 'unverified' bit)
lego4040
Post by lego4040 »
Image my etch and attemp at this circut
lego4040
Post by lego4040 »
Population has begun :applause: ImageImage cannot wait
culturejam
My 2-sided layout is now verified.
Attached is a photo taken with my iPhone. Big camera batteries mysteriously died. :hmmm:
Kunfuz
Post by Kunfuz »
Ok, someone somewhere, i think it was guitarmageddon, posted a mod to krank up the delaytime, but I cant freakin find it :x
Was it just double the value of tha timepot, or am i completely off here?
Kunfuz
Post by Kunfuz »
Edit without editbutton: use a 50K pot (not 10K) for the time! Thanks guitarmageddon Ben!
"Working" at work is an artform I have mastered to Jedi-level...
audioguy
Has thanked: 22 times
Been thanked: 7 times
Post by audioguy »
Kunfuz wrote:Edit without editbutton: use a 50K pot (not 10K) for the time! Thanks guitarmageddon Ben!
Any negative impact on the overall sound?
culturejam
As with just about any delay, the longer the delay time, the more noisy/lo-fi the repeats are.
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
"oh noes, my crap-fi delay has noisy repeats. who would've thought?"
p_wats
Post by p_wats »
I love where this is going, guys! I might have to try that vero layout from a page back.
Great circuit CJ! If you end up with any more boards for it I'm definitely game.
audioguy
Post by audioguy »
Right right- I was just curious how crunchy it got- but in the time that it took me to type this, I could have swapped the pots and found out myself!
allesz
Has thanked: 41 times
Been thanked: 97 times
Post by allesz »
Seiche wrote:"oh noes, my crap-fi delay has noisy repeats. who would've thought?"
:lol: :lol: :lol:
Last week I went to the reharshals with my ad9 (a reissue) instead of the crap-fi and, well, there is some difference in the quality of sound. On the plus side we should say that, since this effect works with super short repeats the quality is quite good thought.
By the way, it is a little off topic but, I have a ring modulator with oscilations and a wite noise generator that is not so good for playing the blues.... maybe I sould switch the caps to better quality ones, I don't know.... :hmmm:
audioguy
Post by audioguy »
just finished this one and its a little dark, rolls off a lot of high ends. I swapped C7 and C1 for .047, not much help. Should I try smaller, or is this just going to be dark?
