[stripboard] Maestro BG-1 Boomerang
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
Factory schemo shows P-2336 transistors for Q1 and Q2 - good luck searching Pinout shown is for BC108B or similar.
Inductor is spaced for typical, common "halo" type. Originally it is indeed 500mH, but about 40R resistance, so no quite "halo" spec... just saying...
Pot taper is also odd - 25k is not easy score
- beedotman
Sinner, input resistor should be 47K in place of "standard" 68K value, right?
I'm refering to this schematic:
- mboomer.gif (7 KiB) Viewed 2875 times
- sinner
I was working with factory schemo attached to the back plate of it. I have detailed picts from Joe Gagan who owns it, I'll check it against errors
- sinner
As you see there is more differences, like resistor value at collector to base in second gain stage
- sinner
- beedotman
yup! this resistor is to simulate transistor leakage, right?sinner wrote:As you see there is more differences, like resistor value at collector to base in second gain stage
cool. thx.sinner wrote:here's the pictures I was referring to http://www.turretboard.org/?p=504
- beedotman
Arteffect SOD has nominal inductance 550mh and nominal Resistance 42.5Ohms, so could be more or less closesinner wrote:Inductor is spaced for typical, common "halo" type. Originally it is indeed 500mH, but about 40R resistance, so no quite "halo" spec... just saying...
According to SBE description
http://www.smallbearelec.com/servlet/Detail?no=1132
- sinner
beedotman wrote:Arteffect SOD has nominal inductance 550mh and nominal Resistance 42.5Ohms, so could be more or less closesinner wrote:Inductor is spaced for typical, common "halo" type. Originally it is indeed 500mH, but about 40R resistance, so no quite "halo" spec... just saying...
Good to know
SOD is spaced differently. it takes .15" pitch vero better, I'll do one for it
- beedotman
hehe. cool!sinner wrote:SOD is spaced differently. it takes .15" pitch vero better, I'll do one for it
- prehistoric
very nice project here, i just found it!
even though the factory schem lists the base Q1 R as 4.7k, i recently noticed our unit has 1.5k, just like the BG2. so the only differences in tone between the BG1 and BG2 would be due to the extra components to make the BG2 a volume pedal in 'off' mode.
i have tried the arteffect inductor (SOD, 550Mh ), it sounds great in a standard BG2.arteffect used to offer the SOD in both 500 and 550 Mh, not sure if they are even still making them.
sinner wrote:Factory schemo shows P-2336 transistors for Q1 and Q2 - good luck searching Pinout shown is for BC108B or similar.
sorry about the question, as for the pin outs underneath the inductor are the black dots connections and red ones cuts?
- Max Cohen
Red dots are the hot inductor lugs. Black dots are supportive whipple lugs. They dont need to be cut off or brake the vero. They have no connection to anything
Welcome to freestompboxes.org
We can help... But we won't
Turretboard.org now with forum
TB.org on Facebook
TB.org on Facebook
- atreidesheir
Pawel, did you ever wind some inductors.
If you did, was it worth the effort?
I used one of these little transformers (from Smallbear) as an inductor with nice results on a Vox wah repair recently. I had one in the bin and it sounded correct.
http://www.smallbearelec.com/servlet/Detail?no=599
Smallbear description reads:
"Transformer - Mouser 42TM013
PC Mount, 1K to 8 ohms. The primary makes a decent, cheap 500 mh. inductor for a Wah or a Wild Mouse."
There are probably other similar small value transformers all over the world waiting to wah.
- Max Cohen
No bro, never had enough of time to focus my ass on it. I still have the electric motors taken out of an old CD and DVD players, and a digital counter. I know where to score the shells, and wire, so me thinks it's just a question of time.
...but - I just changed my work, and the time is what I'm short with
TB.org on Facebook
TB.org on Facebook
- atreidesheir
I understand. There is plenty of time for everything but fun these days here too.
- Professor SourTone
Does anyone have the stripboard layout still? It seems to no longer show up. I had this originally from Turretboard.org years ago but cannot find it anywhere now. This is all I have (thanks to Wayback Machine) but it's tiny and unreadable!
- bg1.jpg (23.82 KiB) Viewed 2379 times
- beedotman
