First up is my take on the Big Muff, which has been a constant on my bench for forever. My fuzzy little mistress, if you will. A few things always bugged me a bit, like the low input impedance, that it was a bit of a one trick pony, the noise at higher gain settings, etc. Screwed around with a bunch of different mods for a long time, and wound up with the Cornish buffer up front and a bog standard BJT buffer at the output, the Blackout Effectors/Earthbound focus/density control at the input, Orman's mid boost and then constantly tweaking layouts and high frequency filtering to lower the noise floor. End result was fairly nice, but the circuit was huge and the focus/density control range is pretty garbage if I'm honest.
I moved on to mictester's 21st Century Big Muff (with the gain control in the feedback loop of the first stage instead of a voltage divider following) in an attempt to simplify, but for some reason the fact the volume wouldn't go completely off always bugged me. So I swapped his output stage for an inverting stage, and added a Timmy bass control to control the low end up front and get some more overdrive-ish tones, and the range blew that of the focus/density control out of the water. I loaned that build out to a buddy, who used it for recording, but he didn't like that it would invert phase when he kicked it on during recording. I didn't really care though and left it as is for a good while since input impedance and gain in an inverting stage was an issue I didn't feel like tackling.
Then, one day, I was thumbing through Walt Jung's "Audio IC Op-Amp Applications" (thanks to Bjorn Juhl for the rec), and saw a high input impedance inverting stage, and decided to try it, with the shelving filter added on of course. It worked pretty god damn well. Though revisiting the circuit, I realized that the range of the "body" control was shit with the gain turned down low, and reverted to using a 100kA pot after the input stage for a gain control, and arrived at the circuit attached. Range of tones is pretty great, and I haven't really heard anything bad about it yet. Low end can get pretty tight with the body control, and the gain can get pretty crazy. Blues, classic rock, stoner, hair metal, doom, thrash, etc. are all in there to some degree. Not the most dynamic circuit, seeing as how the clipping is pretty much bog standard Big Muff, but lots of fun.
In between all this, I dicked around with a gate control (which can still be seen on the revision of the PCB used in my last build), but it never worked as well as I'd have liked, so I removed it.
Circuit is verified, and here's a pic of one of my builds, which also has a switchable buffer on the bypass daughter board. Pretty bog standard bootstrapped voltage follower and buffered Vref, and not terribly interesting, though I guess I could post that if anyone cares.
