Before presenting this project, i would like to especially thank Dosmun (one of our newer members here), for the high resolution pictures he has provided, showing both sides of the PCB and identifying parts values. The pictures amongst other bits and pieces can be viewed in this thread: viewtopic.php?f=1&t=2652
Further thanks is given to Bernardduur and Analogguru for tracing and publishing schematics for this project.
There appears to be some doubt regarding the small ceramic capacitor (100p???) connected to the tone control, but i am sure someone will be able to verify this value in the near future.
Okay here are the files: http://www.student.ru.nl/r.kerkhof/Posts/Juggernaut.jpg
http://analogguru.an.ohost.de/001/schem ... ernaut.gif
members/bajaman/JUGGERNAUT/BAJA%20Mini% ... %20PCB.png
members/bajaman/JUGGERNAUT/BAJA%20Mini% ... verlay.png
members/bajaman/JUGGERNAUT/BAJA%20Mini% ... 0Label.png
members/bajaman/JUGGERNAUT/BAJA%20Mini% ... Label1.png
members/bajaman/JUGGERNAUT/IMG_6745.jpg
Some notes: this unit has 4 sockets: an input and output socket AND a send and return effects loop, to allow other devices to be connected between the distortion stage and the boost stage.
You could simply connect the effects loop wires together if you do not want to use the effects loop feature.
You should have just enough room to mount the sockets under the component side of the board. Dosmun's picture of the ProCo juggernaut shows the method of mounting the board and controls, leds, and footswitches. i will post photos of my Mini Juggernaut in due course.
In the meantime - Happy soldering
