BAJA VH4 overdrive pedal project 290118  [documentation]
Has thanked: 596 times
Been thanked: 2061 times
Hello fellow diyers :D
Here is my latest build based on the frequency response characteristics of the Diezel VH4 tube head channels 3 and 4, but scaled down into a 9v dc pedal friendly format.
I took it around to my friend's house last night for evaluation - we have a monday night four piece jam session where i usually play drums, but last night i got a chance to try using it on Neil Young's
"keep on rockin' in the free world" and needless to say it sounded awesome on very low gain setting Channel 3 - just the right amount of seering crunch and in my view one of my best pedals to date :!:
Again perhaps one of you may like to contribute a vero or stripboard layout and hopefully "rcustoms" will contribute one of his excellent pcb layouts :hug:
Here is the schematic and some pictures of my prototype build.
enjoy :thumbsup
Moderator: double post resulted from merging the two topics having the same subject.
enjoy :thumbsup
rcustoms
Has thanked: 363 times
Been thanked: 520 times
Post by rcustoms »
bajaman wrote:Hello fellow diyers :D
enjoy :thumbsup
working on it,mr baja ,it is a real pleasure to contribute in your amazing projects
guitars,pedals and amps.
@zuleta.rafael(Instagram)
JOHNO
Has thanked: 47 times
Been thanked: 53 times
Post by JOHNO »
Really fantastic work your turning out bajaman, its much appreciated.
I was just wondering if its ok to drop the buffers off this circuit as i dont have the components. I was thinking i could drop every thing before and including the 10k resistor at the input and put the 1m5 before the remaining 1uf cap and do the same on the output. Would that cause any problems apart from possible interaction with surrounding pedals?
Hi JOHNO
thanks for the nice comments - the pedal should work fine without the buffers but may interact differently with other pedals :wink:
FausterCraster
Has thanked: 17 times
Been thanked: 18 times
Post by FausterCraster »
Hi Baja,
another great job !!
In the hard clipping session for your last projects you are using mostly BC547C, can you describe the difference in using these trx Vs the diods ?
TX
they (Philips brand BC547B) clip at a slightly higher Vf voltage than 1N4148 diodes - in this project it enables a slight asymmetry to the clip - (just as the Diezel VH4 amplifier clips because of the cathode follower stage following the final gain stage before the tone stack and the slight non-linearity it introduces). Another way of achieving this would be to use two BC547B and to set vbias slightly higher than half way by using an 8k2 resistor in place of one of the 10k resistors :wink: .
marcao_cfh
Has thanked: 38 times
Been thanked: 30 times
Post by marcao_cfh »
I've added this one to my "to build" list! And I still didn't got time to build your other ODs...
Just another question on clipping. Did you tried the 2n5088/5089?
287m
Has thanked: 481 times
Been thanked: 74 times
Post by 287m »
waiting Liverpool match, draw this. Perf rules :evil: hahaha
Thanks BAJA!
A4-baja-vh4-etch-300-dpi.pdf
(38.62 KiB) Downloaded 241 times
JOHNO
Post by JOHNO »
Got this on the bread board and it sounds great, that is until I connect up the gain pot and most of the gain disappears and the gain knob acts like a volume knob. :scratch: I've been going over everything for hours now and i'm stumped. Any ideas?
JOHNO
Post by JOHNO »
Turns out the 4k7 just before IC1c was bad, swapped it out and "sha bang" it"s time to rip, thanks for sharing bajaman.
rcustoms
Post by rcustoms »
my quote
regards
rcustoms
Post by rcustoms »
switch detail channel 3 and 4
rcustoms
Post by rcustoms »
corrected R11 is 33k
marcao_cfh
Question: are the lugs 2 and 3 of the gain pot really connected together, or should I connect the switch to lug 2 only?
rcustoms
Post by rcustoms »
are connected together and connected too to switch
Here are the frequency response and phase curves for the VH4 Ch3 first and then VH4 Ch4 second :wink:
Danielys
Post by Danielys »
How does this compare to diezels own vh4 pedal?
Optical
Has thanked: 16 times
Post by Optical »
I have the VH4 pedal and VH4 amp and would like to know too :D Should be a good comparison when I eventually get around to building some
HEAD
Has thanked: 24 times
Been thanked: 49 times
Post by HEAD »
Guys, don't let this slip! The channel 3 of the Diezel VH4 is such a legendary sound.
