Vandal - a 2-channel preamp inspired by the Randall RG100ES
I just recently went ahead and tried to build the simpler version of this schematic; just the red channel and I'm having some issues with gain and volume; I've noticed that you've posted that you didn't have good results with 2n5485s; which are the only trannies I had on hand at the time. Is this why?
I assumed that 2n5484s and the 85s were close enough spec wise to be mostly interchangeable... I've gone ahead and ordered some 84s in the mean time and I'll post something else when I get them in, otherwise, has any one else had gain and volume issues with this build?
I've checked over the circuit numerous times and can't really find any issues with it; running it at 24 volts and everything appears to be biased right; no solder bridges either. The sustain switch works, adds tons of gain at the expense of volume, but without the switch engaged the base tone is very clean and only slightly above unity volume. The eq section, gain control, master, and presc all work fine as well. Any thoughts?
- marcao_cfh
2N5485s, maybe? I built the red channel a few days ago using 85s, and had some issues too. Running the circuit at 18V, I got less distortion than I was expecting and volume below unity, even with the switch disengaged. Didn't tried other fets or voltages.
- sixthfloor
That's interesting, my 2n5485s distorted quite a lot contrary to both of your experiences. The trouble I had was with the distortion being kind of farty with too harsh highs; as far as I can remember the other transistor types I used led to the same problem. If i remember well, changing the bias voltages didn't solve the problem - the 5484s were the only satisfying transistors there.
I'm going to be rebuilding the circuit this weekend fresh; with new parts and all. I'll report any updates when they happensixthfloor wrote:That's interesting, my 2n5485s distorted quite a lot contrary to both of your experiences. The trouble I had was with the distortion being kind of farty with too harsh highs; as far as I can remember the other transistor types I used led to the same problem. If i remember well, changing the bias voltages didn't solve the problem - the 5484s were the only satisfying transistors there.
Completely rebuild the board and still have a lack of gain; the volume appears to be a bit better, but the gain is still very weak.
Have tried all different combinations of jfets to no avail; I'm so confused as to what could be causing this.
I mean, I can't have made the same error twice, could I?
Does anyone have a sound clip without a boost pedal in front of it so I can hear what it sounds like?
- sixthfloor
Strat bridge humbucker, full volume -> Vandal red channel, gain 2 o'clock, EQ to taste -> computer speakers -> smartphone.
EDIT: do you want to share your modified layout and/or schematic, to have a second pair of eyes check it ?
- Manfred
- Has thanked: 1623 times
- Been thanked: 1324 times
Where have you purchased your FETs?
Have a look at this post.
viewtopic.php?f=17&t=24756&start=40#p276841
That had been the fourth time that I bought Fets by Chinese Sellers,
whereby the imprinted type not match the type as expected.
Once one time even the P-channel JFET was a P-Channel JFET.
As a result of this experience with the Chinese sellers I will never buy semiconductors from.
Left the Id_Vds curve form the data sheet right one measured curve from Chinese JFET,
all others had almost similar curves.
Thats what mine sounds like for the most part with the sustain switch engaged... Maybe a small bit less gain. Maybe I'm just expecting more from this preamp than it can give, haha!sixthfloor wrote:I just recorded a quick (and crappy) one for you:jarrodthebobo wrote:
Here is the layout I used:http://guitar-fx-layouts.42897.x6.nabbl ... ndall2.png
- Manfred
Hi Jarrodthebobo,
you wrote:
That is why I asked you, about the supplier of the JFETs above.
Perhaps the JFETs not fulfil its specifications.
Could you please measure the set resistance of the trimmer potentiometer voltages at of the JFET terminals,
it could helps to determine the forward conductance of the JFETS.
Is the amount of gain enough now?... Maybe a small bit less gain
- sixthfloor
My sustain switch wasn't engaged though.jarrodthebobo wrote: Thats what mine sounds like for the most part with the sustain switch engaged... Maybe a small bit less gain. Maybe I'm just expecting more from this preamp than it can give, haha!
I think there's a slight mistake in the layout: the G8-A8 link should be G8-B8. As it is, the trimpot doesn't regulate the bias on Q1, which might explain your issues.jarrodthebobo wrote: Here is the layout I used:http://guitar-fx-layouts.42897.x6.nabbl ... ndall2.png
My Q1 biases fine though; got it down to 12.5v using the trimmer.
I'll post resistances and full voltage readouts when I get home... It's odd how clean this thing sounds, almost as if signal is being lost somewhere...
This is the 2nd time building it and having the same issue... So strange!
did you try sixthfloor's suggestion?
edit:
oh actually It's not one wire. It looks like the wire is going from G8 to C8 then there is another wire from b8 to a8.
edit:
- sixthfloor
Yes, I didn't look at the bottom part of the layout. My bad !duckduckgoose wrote:did you try sixthfloor's suggestion?
edit:
no worries. i though the same thing lol.
have you seen this?
https://reverb.com/item/2554060-lpd-eig ... ll-rg100es
looks like they had the same idea.
that was the prototype and now it looks like they are selling a production model
but they don't mention anything about randall now.
https://reverb.com/item/3974100-lawrenc ... llic-black
have you seen this?
Regarding the photo of the hand-drawn schematic. Is this exactly as shown in the perfboard layout? Many of the part values are just about incomprehensible to me, like what the diode numbers are and how a 20uF capacitor at Q2 could possibly be right, or what the capacitor value is between Q2 and the 1K resistor. The writing is kind of ambiguous at best, at least to my eye which is accustomed to clear annotations.
Is the perfboard layout the key to correct values?
Thanks,
Fretts
Thanks,
Fretts
OK never mind - I was able to deduce the component values by referring to the stripboard layout. Wow - some of the handwriting quirks really stumped me for a brief time! Once I translated what was a uF to me into nF, and realized that the 6s and 9s were all actually 4s, it came into focus.
I also had to check the datasheet for the 2n5484 to understand that the Source, Gate and Drain on that transistor is in Drain, Source, Gate order which really twists the layout around when I was trying to correlate the two.
I think I've got it now.
I really love these types of circuits, which are only available in the DIY world!
This is a great pedal; it really captures Dimebag's tone. I call mine " Vandal from hell"
I finished mine using 2n5458 transistors, and it sounds pretty brutal. I'll like to try how it works with J201 next.
I used a 3pdt toggle on the first batch, but I'll go back with the 4PDT for the channel switch.
I really recommend this build to anyone who's looking for an excellent Metal pre-amp.
I have made some PCBs for anyone who'd like to try this brutal high gain pre-amp/distortion.
https://pcbguitarmania.com/product/vandal-from-hell/
I'm here to help you building great pedals.
Check out our boutique effects PCBs at:
Anyone here already built the pedal and is working correctly?
