MAGNUS MODULUS - PROJECT - PT2399 ECHO/Chorus/Tremolo/Boost [documentation]
Well, I finally managed to complete this project, and it works great!
I'm a little uncertain about the Gain control, though - I couldn't hear any difference between full cw and full ccw at the test run yesterday evening. Anything wrong? Suggestions for how I can fix it?
Thank you Forced Fire for sharing this cool pedal design!
- DahakaNishoba
Just built one using Cathexis Veroboard....
Had some tremolo first try then NOTHING.....signal is ok and the GAIN works (a lot....) I have to set it 2/10 for no boost...anyone used cathexis vero and noticed something ?
the only other thing I hear is a little POP on one of the switch
I used some 2x047 caps in parallel instead of the 1uf NP.....hope this isnt a big issue....
The way electronics work in a stompbox is like the way pixels move in a videogame
it's Magic, in Technology
Here's my "hack" to deal with enormous boost and still have decent tremolo:
I was having one 150k B pot laying around so idea was to lift up depth so I can lower gain. I've noticed that depth switch is only active about 7/10 to 10/10. And so I swapped 100k for 150k depth pot and lowered the gain (trimpot) to 2/10. (I suppose you could also lift up 100k with resistor in series)
Now my pedal is transparent and have zero boost.
Hey everybody!
I just finished this wonderful project - it works fine and sounds great. I keep confusing the controls, but thats another story.
But a have question:
The LM7805 gets VERY hot, and I'm not sure if it's a good idea to use this pedal for a long time or even on a hot stage.
Mine looks like this:
I was not able to find the smaller version.
Is this normal?!
Thanks alot!
Is this normal?!
Thanks alot!
- Bside2234
I used a 7805 and mine doesn't get hot at all.pirxpilot wrote:Hey everybody!
Is this normal?!
Thanks alot!
Yeah you should probably find LM78L05. And also check pinout of that LM7805. (maybe it needs to be rotated by 180° )
follow up : u should check correct pin of LM7805 " 1 " input(9V) , " 2 " ground , " 3 " output (5V)whosyourdaddy wrote:Yeah you should probably find LM78L05. And also check pinout of that LM7805. (maybe it needs to be rotated by 180° )
" 1 " Pin should left side when u see front of regulate.
my expeirence incorrect pin cos' ic hotter than normal but fix by reverse 180' pin or u see datasheet.
- lufox15
Hi, i'm new in this forum. and i don't understand what do the switch delay tails, if i push the the bypass switch, it's not the same??, and the tremolo or chorus effect, continue sounding if i push the delay tails switch???.ibodog2 wrote:OK, what is the "tails" switch supposed to do? Leave the delay tails on when the effect is bypassed? But, no that can't be it if I wire the board up the normal 3pdt "true bypass" way.
thanks. sorry about my words i don't speak english.
- Barcode
"tails" is probably a misleading name. It actually turns the delay on and off, like the tremolo and modulation switches.
i just built this, and unfortunately, i have no tremolo, and barely any modulation. delay works fine???
- Barcode
nevermind, tremolo is working, but it has a loud thump with every hit, whether I'm playing or not. I also think I've either made a resistor mistake or I got some mislabelled parts, as the rate and depth knobs have a narrow usable range. anyone else find this?
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 70 times
- Been thanked: 66 times
- Contact:
Tell me if i'm wrong, but i understood that the "tails" switch allows disengaging the delay while letting the last repeats fade away (hence the name). A kind of smooth end to a delayed phrase, at the price of not being true-bypass.Barcode wrote:"tails" is probably a misleading name. It actually turns the delay on and off, like the tremolo and modulation switches.
I don't know how it affects tremolo and modulation.
- Bside2234
My depth knob only works the last 1/4 of the turn and my rate knob only works on the 1/2 of the turn. I'm going to adjust their values/tapers as soon as I get a chance to make them work better. I eliminated the tremolo on mine because I didn't like having to turn the gain/boost up so high to make it work but I didn't have any thumping when I had it on there.
- lufox15
so, if i push the "tails" off, the tremolo it's on?, or i don't have tremolo, mod and delay with the "tails" off????JiM wrote:Tell me if i'm wrong, but i understood that the "tails" switch allows disengaging the delay while letting the last repeats fade away (hence the name). A kind of smooth end to a delayed phrase, at the price of not being true-bypass.Barcode wrote:"tails" is probably a misleading name. It actually turns the delay on and off, like the tremolo and modulation switches.
hi , i hace one cuestion for you man , were you find these boxes ?, i can´t find them , im find the pots the ic ,the compnents , all , but the boxes i can´t find....... can you help me?....... thankslochy wrote:yea I get the pop when I switch on tails. normally I just leave the tails on and just switch it on and off.
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
http://www.effectsconnection.com/oscomm ... 859c2c4ac8maikyguitars wrote: hi , i hace one cuestion for you man , were you find these boxes ?, i can´t find them , im find the pots the ic ,the compnents , all , but the boxes i can´t find....... can you help me?....... thanks
they have a bunch of different sizes, some large enough for the MM project easily
Anybody knows where to get these knobs (with color!)? They look great and look perfect for a "knobby" project!maikyguitars wrote:
Thanks.
“Happiness in intelligent people is the rarest thing I know.” - E. Hemingway
