Maestro FZ-1 on Turret Board!
- soulsonic
I just built an FZ-1 on turret board for a friend. It turned out GREAT! I used the original schematic with the corrected parts values that Modman has posted in Wiki article about the FZ-1. It's a very compact build too, I was able to fit it in a small 1290 box with no trouble. It's powered by two AAA.
I was really shocked how warm this circuit sounds. I was expecting mosquito tone, but it's not like that at all and it gets some very nice harmonic complexity on chords.
I used a mixed bag of different transistors and it seems to do it's thing well without any other change in component values. The trick seems to be to have fairly leak-y transistors for Q2 and Q3 to help it bias rightly.
Photos and build details to follow soon... just need to upload the stuff off my camera first.
- soulsonic
It's sounds totally different than the Fuzz Face. It's brighter, but not in a shrill way - it's more clear sounding... no mush on chords at all, lots of definition. It's really a totally different animal and completely different color.
- soulsonic
Here are the pics of my build:
Guts:
Up close of the board:
- telecaster
That's excellent!
KindaFuzzy - Looks like a blue nail polish and nutella sandwich.
Freekish - "Our originality is in the basement. Our business is in the toilet"
Guitarlcarl - I did take offence at being called an idiot by a moron.
- soulsonic
It's a rubber stamp kit I got from a craft store. The ink is solvent-based stamp ink.
Fuzzer wrote:How do you do that labels Soulsonic?
- soulsonic
Right here in our own Wiki!jrod wrote:Very cool! I like the stamps, too!
Can someone direct me to the CORRECT FZ-1 schematic? Thanks!!!
wiki/doku.php?id=maestro_fuzz-tone_fz-1
Big thanks to Modman for his excellent job researching and writing the article. It's a real gem!
- RnFR
is there a proper way to bring the voltage down from a 9V so you don't have to use the AA's? diodes? resistors?
- soulsonic
You could get a zener diode around 3-ish volts and use it with a resistor probably in the 1k to 3k range wired up in the usual simple voltage regulator way and that should probably work. Or, you could use a variable negative voltage regulator and set it to 3v. Or you could do the thing with a voltage divider potentiometer feeding an opamp buffer... that's supposed to be a pretty decent regulator.
But c'mon, two AA or AAA are so cheap and easy. You can get the battery holder from Rat Shack. I went with the AAA because they're cheaper than 9v and you don't have to "throw away" a bunch of energy to give it the right voltage.
Don't they make a 3v battery? I'm sure I've seen them in catalogs, and they were small-ish too.
LM317; you just need two resistors, and two capacitors.
But the Zener Diode should work well;
Also, you could get one of those pretty TO-92 7805 and then put a red LED after it, it should leave you with approx. 3 [V].
- HydrozeenElectronics
That is totally sweet!
- soulsonic
Thanks! This was my first ever homemade turret board. I got the supplies to do it from Hoffman Amps. I'm totally hooked on the turret board thing now! It's much easier than etching pc boards; all you have to do is drill the holes and stake the turrets in place. And since several components can share a common turret (like a ground turret or power turret), you don't need to drill nearly as many holes anyway.HydrozeenElectronics wrote:That is totally sweet!
I'm working on a Fuzz Face right now that uses a six lug turret terminal strip I knocked together.
- RnFR
i've been thinking of getting some of those turrets from hoffman for a while. i even made a couple of layouts already. about how many components can you fit on a turret? because, i made a layout for the dirty boots, and i think i need to put 4 or 5 comonents on one turret in a couple of places. are these turrets big enough?
I have been wondering how well turret would work out for fuzz pedals for a while now. I'm sold thanks for posting. I can't wait to see your Fuzz Face on Turret!
- soulsonic
Here is the Fuzz Face I was talking about. Maybe next time I'll use more lugs so there's not as much "off board" stuff hanging.
The pcb on the left-hand side is the power circuit and an order-swapping switch - this is a dual unit with a Rangemaster... kinda like a Sun Lion... except, like, way better."Analog electronics in music is dead. Analog effects pedal design is a dead art." - Fran
