Analog Delay Add-Ons - Double Time, Modulation, Exp
abfackeln
Been thanked: 29 times
Post by abfackeln »
@ gitaar0....
Have you checked all of your connections? Sounds like a potentially bad solder joint somewhere.
Have you tried a different photocell/LDR value?
gitaar0
Post by gitaar0 »
abfackeln wrote:@ gitaar0....
I checked and double checked them, but I will sure check them again.
I have not had the chance to change the LED/LDR combo. I will do that too.
Did you have it working with the aquaboy (double delay time board included) and be able to use all of the range of the depth pot?
Thanks, Marc
gitaar0
Post by gitaar0 »
I checked the soldering and that turned out ok.
Changed the LDR (tried a few) and that made a difference. I can now use the whole range of the depth pot without the delay cutting out. That is good, but with the depth pot down I still have modulation. Is there something I can do to have all the modulation gone with the pot turned down (without having to find yet another LDR)? I already changed the resistor before the led but that did not solve it yet.
Any suggestion?
Marc
plugzzzz
Post by plugzzzz »
gitaar0 wrote:I checked the soldering and that turned out ok.
Any suggestion?
Marc
had the same problem what i do is i turn the rate/speed of the modulation full that solve it....
another problem i have is that the delay has a very small amount of overdrive specially if i pick the strings hard is there a way to fix it
thanks
gitaar0
Post by gitaar0 »
[quote="plugzzzz"]
thanks[/quote]
Hi Plugzz,
I guess you are talking about the aqua puss delay?
I had that same problem.
There is a thread at [url]http://www.madbeanpedals.com/forum/inde ... pic=262.15[/url]
"My experience was that the BBD was getting too much signal and that was causing the BBD to distort.
I replaced R15 with a trimpot to find out at what value the signal was loud enough and clean enough. Then I removed the trimpot and measured the value at wich the trimpot was set and used that value for the resistor at R15. So yes you can substitute R15 with a different value, but you have to find out what works for you I ended up with 56k."
Marc
hoyager
Post by hoyager »
Is there another way besides turning the mod rate on full to stop the board from modulating that anyone has discovered? I've just built another aquaboy with mod and dd, and it has turned out with the same problem, I'm a bit suprised not many others have noticed.
Also is there a mod, or way to making the minimum rate even slower? like, unbalanced 33 slow? or drifty old synth slow? or is the tl072, the limiting factor in this?
Andy
plugzzzz
Post by plugzzzz »
thanks
Hi Plugzz,
There is a thread at http://www.madbeanpedals.com/forum/inde ... pic=262.15
Marc
thanks will try your solution on the distort problem see if that work on my built
abfackeln
Post by abfackeln »
Double Delay boards are now all sold - no more in stock. :cry:
gitaar0
Post by gitaar0 »
Any suggestion?
Marc
Bump
binog15
Post by binog15 »
Hi, iam from Brazil, escuse my poor english.
I don´t have osciloscope.
I have a problema with calibration of Aquaboy, closest I came was a reverb.
I follow all pdf´s instructions, but nothing.
I build it with MN3005.
Anyboy can help me.
i wait, thanks
sorry if posted in wrong place.
abfackeln
Post by abfackeln »
If it's an Aquaboy you're working on, you may want to try posting over in madbean's forum:
Photos are always helpful.....
B_of_H
Post by B_of_H »
abfackeln wrote:Double Delay boards are now all sold - no more in stock. :cry:
are you going to make more? I just logged on to order a few.
abfackeln
Post by abfackeln »
B_of_H wrote:are you going to make more? I just logged on to order a few.
Right now the demand is not high enough to justify another order without them being prohibitively expensive.
If demand picks up, I'm certainly open to making another order.
danielzink
Completed builds: Too many: www.danielzink.com
Been thanked: 27 times
Post by danielzink »
binog15 wrote:Hi, iam from Brazil, escuse my poor english.
Anyboy can help me.
i wait, thanks
My question is - are you positive that you're using genuine MN3005's ?
Dan
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
B_of_H
Post by B_of_H »
fair enough.
tuemmueh
Post by tuemmueh »
So here's interest in two more boards!
omarvolta
Post by omarvolta »
I'm interested in two double time and one modulation.
"Play from your fu*#%ng heart!!!!" Bill Hicks.
globalk
Post by globalk »
First post! I'd grab four DD and 4 mod.
B_of_H
Post by B_of_H »
i'll take 4 dd and 2 mods if they become available again. :horsey:
Scruffie
Has thanked: 28 times
Been thanked: 170 times
Post by Scruffie »
Or how about Quadruple Time Delay Boards with a 4049 Buffer on board :wink:
I might take one or two more DDs depending on how certain projects go.
