FS: Rebote delay, & some loaded PCB's incl Bad Stone
- timbo_93631
- my favorite amplifier: Low wattage SE amps
- Completed builds: Many many many true bypass and voicing mods on wahs.
A few BYOC kits and DS-1 mods and eventual murder then rebirth into an actually useful pedal, Bad Stone clone, various Rangemasters/SilconMasterBlaster, The worlds greatest gutted GCB-95 volume pedal conversion with various switching options for controlling amps. Repaired many tube amps, scratchbuilt Marshall 18 watt clone and Supro 1616t rebuild. Delays, fuzz, dirt, every Madbean project I could afford. I even manage to find time to make babies with my wife too! - Location: Fresno, Ca
- Has thanked: 14 times
- Been thanked: 33 times
Hey guys,
Have some stuff for sale over at Madbean's and I thought I'd post it here too:
Rebote 2.5 Delay
Works great, complete pedal in a 125b with top monted jacks that makes it hard to find a place for on my pedalboard. I didn't build it, another forum member from Madbean's did and offered it in a fundraiser I took part in. A good solid delay pedal for cheap. $40/shipped in the US.
Bad Stone Phase Shifter loaded PCB
From the group buy here. Works, but the solder pads on the LPB section are starting to lift. Never attempted to get that section working, instead I used Madbean's Fatpants (below) to even out volume and tone. There is gorilla glue residue from where I had put foam behind the pots, but is all cleaned from solder pads and 99% of the gorilla glue was removed. No Pots, jacks, or switches. $20/shipped in the US
Madbean FatPants Echoplex Preamp
Fabbed board from MB's. All there except for the trimpot, I used a resistor from pad 1 to pad 3. No pots, jacks, or switch. $9/shipped in the US
Tonepad Mosfet Boost
Single sided fabbed board, all there and works. No pot, jacks, or switch. $5/shipped in the US
For international shipping: rate will be actual cost -$2
Will make a package deal on the Fatpants and Rebote Delay
Will have pics of the Rebote up Thursday
Rebote 2.5 Delay
"I wish to be in the situation of non killing my balls bills, and life surprises." -Sinner
"Everyone gets their shorts in a twist over who polished the fenders. No one cares about who designed the engine..." -DougH
- timbo_93631
You would need 2 SPDT toggles, a 3PDT stomp, two 100kB pots and a 1mB pot to use all of the options/mods.
Here are the important links:
http://www.digitaldestruct.com/BadStoneBOM.txt
http://www.digitaldestruct.com/BadStoneSchematic.bmp
https://www.freestompboxes.org/viewtopic ... 17&t=10645
viewtopic.php?f=13&t=8424&hilit=Bad+Stone
- timbo_93631
I also have an etched Dig Dug (seek wah clone) unpopulated PCB set from Haberdasher on MB's forum. $13/shipped in the US
- timbo_93631
The Fat Pants is a simple boost based on the EP-3 Echoplex preamp input. Basically it has a Max1044 charge pump running a Jfet at 18v for high headroom and then a volume and fat control. The fat control could be called a Skinny/Fat control because the first part of the pot rotation is all twangier tones and the second part the tone gets fatter, with the tone about the same as without the boost in the middle. A nice booster that doesn't have the noise and hiss of some Mosfet based boosts. It is nice to make a dark pedal or pickups brighter, or treble laden pedal or pickups fatter, not muddy. It is alot like an Xotic EP booster
Here is the build doc from Madbean:
- timbo_93631
PM Replied.
I also have two unpopulated Madbean Dirtbag Deluxe fabbed PCB's I might part with.
- timbo_93631
- timbo_93631
Rebote pending
- timbo_93631
Rebote Sold
Fatpants Sold
Mosfet Boost Sold
Still Available:
Bad Stone Available $20/shipped
Dig Dug Unpopulated PCB's $13/shipped
Madbean's Dirtbag Delay/Deluxe Memory Man, Unpopulated Fabbed PCB, $15/shipped
Fatpants Sold
Mosfet Boost Sold
Still Available:
