Garage Sale: 3PDT ~ Transistors ~ Knobs ~ Oddballs
LucifersTrip
my favorite amplifier: Companion Psychedelic Machine
Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
Has thanked: 19 times
Been thanked: 70 times
Post by LucifersTrip »
Update (deletes): A bunch more oddball garage sale stuff from years of accumulation.
Black = I have only what is pictured
Red = I have more than what is pictured
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
1) pot covers pulled from new 16mm pots, 10/$1
2) ¼” jack w/nut, unused, .50
3) 100 ohm pot, not common, great for sagging the battery, new, $2
4) 50 ohm pot, not common, unused, $1.50
5) 3PDT pushbutton stomp switch for true bypass, new, $3
6) 1.5v battery holder, less common version with metal tabs so you can connect
them in various combos for 3v, 4.5v, 6v, etc, new, 2/$1
~PART 2~
10) copper scourer for soldering iron, new, $1
15) 2N2369 Si NPN hfe ~ 50-80 (Peak Atlas measured), vintage metal case, gold legs, US made pre-1968, unused, $1
16) GT5253 Si NPN hfe ~ 150-400*, vintage metal case, gold legs, US made pre-1968, unused, $1
(*if you need a specific hfe within that range, just ask and I'll try to find it)
17) 1N192 Germanium glass case diode, vintage US made pre-1968, unused, 2/$1
18) Texas Instruments, J3151 Si PNP, hfe ~ 45-75, vintage metal case, gold legs, US made pre-1968, unused, $2
19) 4JX11B1634B Si NPN hfe ~ 50-60 (Peak Atlas measured), vintage metal case, gold legs US made pre-1968, unused, $1
20) odd vintage non-latching SPST push switch, normally open, used, $1
22) 555 timer IC, NE555P, new, 4/$1
~PART 3~
26) 3 knobs, 1 large, 2 small (1 not pictured) knurled shaft, for one size smaller than 1/4" shaft, all 3/$1
27) silver knob (~ 1 3/16") for 1/4" knurled shaft, 70's or 80's ?, $1
28) 2N2270 RCA Si NPN, vintage metal case, US made, gold legs, sealed in pack, $3ea, 2/$5
30) 24PDT rotary switch w/ knob, very tough to find, usually these have many tiers/decks this one is heavy duty & more compact, pulled from unused box, $12
34) Texas Instruments, SM2349 Si PNP, hfe ~ 35-60 (Peak Atlas measured), vintage metal case w/ white dot on top, gold legs, US made, unused, $2ea
36) PET4003 Si NPN, hfe ~ 300-500*, vintage black & white case, gold legs, US made, unused, $2
37) 2N3638 Si PNP,hfe ~ 40-60 vintage black & white case, gold legs, US made, unused, $2, few left
37a) 2N3638 Si PNP,hfe ~ 20-30 vintage black & white case, gold legs, US made, unused, $1
40b) 2n1499 (not pictured) vintage split gold & silver metal case, gold legs, US made, DMM measured hfe >100 w/ extremely high leakage, for diode use, unused, .50ea, 1 left
41) Parco Products Germanium PNP, no #, vintage metal case, silver legs, US made, DMM measured hfe > 100 w/ high leakage, $1ea, 1 left
43) (not pictured) PNP silicon, no #, vintage pre-1968 metal case (similar to #34), gold legs, US made, hfe < 10, for diode use, unused, 3/$1, 3 left
~PART 4~
44) GE Transistor Manual Including Signal Diodes, 1962, 456 pages, $4
46) 100K pot, knurled shaft, pulled, $1
48) 2.5K pot, unused, knurled shaft , $1
51) 27PDT rotary switch w/ knob, very tough to find, usually these have many tiers/decks. this one is heavy duty & much more compact, pulled, $12
52) 24PDT rotary switch w/ knob, very tough to find, usually these have many tiers/decks. This one is heavy duty & more compact, pulled, $12
57) vintage knob (~ 1”) for ¼” knurled shaft, .50
~PART 5~
60) vintage pcb with Sprague components: caps (3) TE1162 ($2+ ea at Mouser), (1) TE1160 ($2+ at Mouser), (2) 10DB6A rectifiers, (1) Koolohm wirewound resistor, (4) 1K 1% resistors. Also: 4 fat (metal?) can diodes, 3 more caps (.1) and various bradley resistors. Also, 2 extra chunks of a 1961-62 circuit board with more Bradley resistors, $5
http://www.mouser.com/ProductDetail/Vis ... 1na94eI3MY
http://www.mouser.com/ProductDetail/Vis ... dB2caWWNnR
62) pair of cool looking vintage knobs (~ 1 5/8”) for ¼” shaft, w/ set screw, $4
63) normally open spst pushbutton switches, 3/$1
~PART 6~
72) vintage (60’s or earlier) turret board, $3
73) 20 x vintage (60’s or earlier) 510K resistors, $1
74) 8 pieces of heavy multi-strand wire, each 4”-5” long (over 3 feet total), these were attached to a $200 vintage relay switch, .50
78) 198K pot (measured), 1/4” smooth shaft, unused, $1
79) 10KA pot w/ on/off switch, ¼” smooth shaft with washer & nut, pulled & clean, $1
80) 82K pot (measured), black ¼” D shaft, unused, $1
81) mystery vintage board w/ 4 germaniums (2 x 2SB75, 2 x 2SB156), 2 transformers (S6286C, S6285B)…and a bunch of caps & resistors, $7
83) Fuzz Face germanium PNP pair: After posting my last couple garage sales, so many people asked me the same question:
“Would it sound good in a Fuzz Face?”…so I pulled out my Fuzz Face Tester and went through a load of germs. I carefully chose pairs that not only sounded good, but also hit the 4.5v sweet spot very near the 8.2K stock resistor. The 3 numbers following Q1/Q2 are Q1 hfe, Q2 hfe and the resistor needed to get 4.5v on Q2’s collector. I used a Peak Atlas for the hfe. p=pulled, m=medium/clipped lug - long enough to solder, s=short/clipped - best for socket Image , n=unused. All are metal cans.
f) 2N633 ps / 2N633 pm (64, 102, 10K), $5
i) Parco “Mix” [gold lugs] n / 2SB56 pm (66, 102, 5.1K), $6
k) 2N633 ps / 2N633 ps (50, 61, 6.14K), low gain like AM Sunface, $4
q) MP16B n / MP16B n (78, 90, 9.6K), $5
r) 2SA221 n / 2SA221 n (152, 197, 11.4K), $6
s) 1T308B n / 1T308B n (73, 86, 6.4K), $4
t) Texas Instruments 6502 ps / Texas Instruments 6142 ps (58, 180, 6.39K), $4
v) General Electric 4JX1C610 (black can) pm / General Electric 4JX1D630-9 (black can) pm (62, 97, 6.6K), $6
x) 2SA221 n / 2SA221 n (141, 222, 12.7K), high gain, $6
z) (no#, labeled "out") n / (no#, labeled "out") n (85, 128, 8.39K), $6
aa) MP16B n / MP16B n (63, 88, 7.4K)
bb) 2N188a (black can, pinch top) m* / HEP253 m*, *approx 1/4" lugs, $5
84) vintage Silicon Fuzz Face pair
b) 2N2243A [gold lugs, metal can] n / GT5253 [gold lugs, metal can] n (112, 293, 5.53K), NPN, $4
c) M9432 [gold lugs, metal can] m / M9308 [gold lugs, metal can] m (90, 119, 5.05K), PNP, $4
http://www.talonix.com/shop/item.aspx?itemid=5282
http://www.talonix.com/shop/item.aspx?itemid=11188
86) vintage knobs, (~1 7/8") for 1/4" shaft, w/ set screw, pair $4
~PART 7~
…no cheap Alpha pots here. Most are made in the U.S.A. all pots are clean, unused = no solder.
(some come with nuts/washers)
94) 12K (measured), A-B, heavy duty vintage pot, ¼” smooth shaft, unused, $1
95) 1.3K (measured), medium duty vintage pot, ¼” smooth shaft, used, $1
96) 10K (measured), medium duty vintage pot, ¼” shaft, slot top, unused, $1
97) 275K (measured), Ohmite, heavy duty vintage pot, ¼” smooth shaft, slot top, used, $1
98) 1K (measured), Clarostat, medium duty vintage pot, ¼” smooth shaft, D-top, used, $1
99) 120K (measured), A-B, heavy duty vintage pot, ¼” smooth shaft, used, $1
100) 10K (measured), medium duty vintage pot, ¼” smooth shaft, used, $1
101) 3” x 4.75” perf w/ 1 corner used, $1
102) old DPDT lighted pushbutton switch, comes with 2 color tops, sealed, $4
103) old 1 pole, 11 position rotary switch, sealed, $2
104) heavy duty DPDT toggle switch, unused, $2
105) vintage heavy duty SPDT, used, $1
106) vintage heavy duty SPDT, center off, unused, $2
107) vintage heavy duty SPDT toggle switches, .50 each
108) 10M Clarostat pot, smooth shaft, used, $4
109) silver solder, $2 each
110) transistor heatsinks for classic metal can types, 7/$1
111) vintage solid metal knob (~1”) for ¼” shaft, w/set screw, cool, $3
~PART 8~
118) vintage turret board ~ 1.5" x 3", 5 lugs per side, good for Fuzz Face, $4
http://www.turretboard.org/wp-content/u ... zf1966.png
119) vintage turret strips of 14, each can be cut in two to get 7 per side, good for many vintage distortions & fuzzes, $2 each
http://www.turretboard.org/wp-content/u ... turret.png
120) vintage turret strips of 12, each can be cut in two to get 6 per side, good for many vintage distortions & fuzzes, $2
121) 8.3K (measured) vintage pot, w/ DPST on/off switch, with knob, used, $2
122) 5K, vintage pot, 1/4" smooth shaft, unused, $1
123) 20K (measured) vintage pot, 1/4" slot shaft, used, $1
124) 1M vintage pot, 1/4" smooth shaft, slot top, unused, $1
125) 118K (measured) vintage Allen Bradley pot, 1/4" smooth shaft, slot top, unused, $1
126) 900K (measured) vintage pot, 1/4" D-shaft,used, $1
127) 10K (measured) vintage pot w/ SPST on/off switch, 1/4" knurled shaft, board mount, used, $1
128) 10K (measured) vintage pot, 1/4" knurled shaft, slot top, used, $1
129) 500K (measured) vintage pot, 1/4" knurled shaft, board mount, used, $1
130) 430K (measured) vintage pot, 1/8" smooth shaft, used, $1
131) 5K (measured) vintage pot w/ SPST on/off switch, 3/16" D-shaft, board mount, used, $1
132) 5K (measured) vintage pot, 1/4" smooth D-shaft top, used, $1
133) 25K (measured) vintage pot, 1/8" smooth slot top, used, $1
135) vintage lamp/bulb holder, used, $2 each,
136) vintage lamp/bulb holder, small, used, $1
136.5) mono jacks, 2 left, new, .50 each
137) vintage lamp/bulb holders, 3 large, used, $1 each
138) vintage lamp/bulb holder, small, used, $1
139) vintage SPST heavy duty switch, used, .50
140) vintage SPST heavy duty switch, used, $1
141) vintage DPDT heavy duty switch,used, needs de-soldering, $1
142) vintage transistor washers/spacers, 8 for medium can, 2 for small can, .50
143) 12 volt DC wallwart for standard jack, 1.5A, 18W max, center +, $4
144) 5K trimpots, not the super cheapo ones, Bourns 3386, 13 count, $3
145) vintage large knob w/ metal skirt numbered 0-100 by tenths, (~2 3/4”) for ¼” shaft, needs set screw, $4
146) vintage (70's?) knob pair w/ metal skirt, (~2 3/8”) for ¼” shaft, 1 needs set screw, $5
147) pair of vintage heatsinks with an NPN germanium (IBM 6335 & IBM 6145) glued (?) into each (short leads), hfe 95, 44 (peak Measured), $5
150) vintage knob pair, (~2 1/2”) for 1/4" shaft, cool, long & thin w/ ridged handle, w/ set screws, $4
151) vintage solid metal knob painted black (some paint chipping), (~1 5/8”) for 1/4" shaft, w/set screw, $2
152) vintage knob pair, (~1 1/8”) for 1/4" shaft, 1 needs set screw, $3
153) vintage knob trio, (~1 1/8”) for 1/4" shaft, w/ set screws, $4
154) old stick-on feet (4) for stompbox, .25, 2 left
~PART 9~
155) vintage monster knob, (~4") for 1/4" shaft, w/ set screw, $5
156) vintage large knob pair (~2 3/4") for 1/4" shaft, metal skirt numbered 1-100, one needs set screw, $6
157) 3 1/2" speaker, pulled and clean, $1
158) vintage knob pair (~1 3/8") for screw shaft < 1/4", $2
…no cheap Alpha pots here. Most are made in the U.S.A. all pots are clean. unused = no solder.
159) 24K (measured), vintage pot, 1/4" smooth shaft, used, $1
160) 125K (measured), vintage pot, 1/4" smooth shaft, used, $1
161) 12K (measured), vintage pot, 1/4" smooth shaft with slot top, unused, $1
162) 330K (measured), vintage pot, 1/4" smooth shaft, used, $1
163) 3K (measured), vintage pot, 1/4" smooth shaft, unused, $1
165) 5K (measured), pot, 1/4" smooth shaft, D top, used, .50
166) 50K (measured), vintage pot, 1/4" smooth shaft, used, $1
172) vintage knob, (1 1/8"), metal skirt numbered, for 1/4" shaft, needs set screw, $1
176) various vintage standoffs, $1
177) 5 X SPDT slide switches, new, $1
No high shipping....I'll mail for the real cost.
shipping outside of US: small components ~ $3-$5 (1-3 ounces) and slowly up from there...
US: free shipping with $25 order if no heavy items.
LucifersTrip
A couple notes: I'm running low-ish on #83 (Germanium Fuzz Face pairs), so next part (Part 10) will have sh*tloads more, including hybrids and even some low gain, metal can, vintage silicon.
Also, since I've had so many requests for the 3PDT's (#5), I will give free shipping in the USA if you order 8+
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
bb) 2N188a (black can, pinch top) m* / HEP253 m*, *approx 1/4" lugs, (63, 104, 7.7K), $5
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
[free ship in USA if you get 8 or more]
~PART 2~
15) 2N2369 Si NPN hfe ~ 40-100 (Peak Atlas measured), vintage metal case, gold legs, US made pre-1968, unused, $1
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Due to another friend leaving the hobby and some other wacked out circumstances, I'm blowing out the 3PDT's for a short time, 10 for $25 with FREE SHIPPING in the USA.
5) 3PDT pushbutton stomp switch for true bypass, 10 for $25 PPD USA
Next update will have a bunch more vintage knobs & vintage germanium & silicon Fuzz Face pairs...
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
I was asked by a bunch of people whether I would mail the 3PDT's outside the USA. I can do it for $30 ppd if PayPal payment is sent as "gift".
LucifersTrip
BLOWOUT CONTINUES: 3PDT switches: 10 for $25 with FREE SHIPPING in the USA. (#5 below)
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
5) 3PDT pushbutton stomp switch for true bypass, new, 10 for $25 ppd USA
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Update: A bunch more oddball garage sale stuff from years of accumulation.
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
5) 3PDT pushbutton stomp switch for true bypass, new, $3 ea, 10 for $25 ppd USA, $27 ppd Canada, $31 ppd other
~PART 2~
~PART 3~
28) 2N2270 RCA Si NPN, vintage metal case, US made, gold legs, sealed in pack, $3 ea, 2/$5
~PART 4~
~PART 5~
~PART 6~
r) 2SA221 n / 2SA221 n (152, 197, 11.4K), high gain, $6
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
5) 3PDT pushbutton stomp switch for true bypass, new, $2.50 ea
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
US: free shipping with $25 order < 13 ounces.
LucifersTrip
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
LucifersTrip
Update: Deletes (all Allen Bradley pots sold)
Part 1
Part 2
Part 3
Part 4
Part 5
Part 6
Part 7
Part 8
Part 9
~PART 1~
5) 3PDT pushbutton stomp switch for true bypass, new, 10 / $24 ppd USA
~PART 2~
~PART 3~
~PART 4~
~PART 5~
~PART 6~
~PART 7~
~PART 8~
~PART 9~
