Chinese 3PDT switches
Hello I ask a question, the switch 3PDT, where I can know that the product is of good quality before buying? for the price, I do not think so! I have failed ..
Buy from Daier 20 units, and I have many problems, and I buy in Mammoth problems, eventually fail.
Anyone know of any Chinese seller that good?
- roseblood11
- phatt
Well you are not alone,, I have no doubt somewhere on the planet someone makes good quality switches but I've never been able to find them.
@ " roseblood11" Those are the common units which may well be the switches *A1full* already has and although they might look ok they are prone to fail,, Out of 20,, I've had half fail within a year.
If you pull them apart you will see they are very basic in design, just tabs of tin,, the rocker is very cheap brittle plastic which often breaks. which is about the worst possible switch action for a stomp pedal.
Phil.
Phil.
- Blitz Krieg
at what price point?phatt wrote:someone makes good quality switches but I've never been able to find them.
http://www.newsensor.com/ProductHighLig ... ProId=1476
roseblood11 wrote:https://www.ebay.com/itm/LOT10-3PDT-9-p ... 1162714262
What is the difference with others? all look the same.
as knowing that work well? if the problem is with the months of use, they begin to malfunction.
It's amazing but true, there is nothing to indicate which works well and what works badly. The problem is as you say, over time failphatt wrote:Well you are not alone,, I have no doubt somewhere on the planet someone makes good quality switches but I've never been able to find them.
Phil.
- phatt
Yep,, sadly you have no way of knowing how well they are made without pulling one apart to check.
The units *Blitz Krieg* linked to look different so maybe try a few and see how they perform.
meantime I'll see if I can dig up some old pictures of the inside of those cheap switches.
Phil.
Phil.
