HH electronics - Clockwork Concubine  [schematic]
GraveyardDude
Post by GraveyardDude »
Anybody figure out how to make the 7 pin plug and where they cut got the parts?
Has thanked: 221 times
Been thanked: 841 times
Obtaining a 7 pin DIN connector should not be that hard. Same for a chassis mount as the contra plug. As for the supply voltage, use anything over 13.6 volt and the bitch should start to sing. To get the lights on will take a higher voltage though
akestromer
Post by akestromer »
I think I've finally figure it out.
View from front.
https://3.bp.blogspot.com/-nSq20dKQ0AU/ ... clkwrk.jpg
I'll try to make more sense of it soon.
Danwarren
Post by Danwarren »
Hey there, big thanks to Ake and Dirk for the information, don’t think I’d have got so this far so quickly without it 😊
I brought one last week for £20 in a junk shop and didn’t really know much about it. I’ve now run it off my bench supply and had a listen! All works good…
I was puzzled by what Dirk has tagged as V_OSC net and the third Zener, which made no sense to me as there was already a Zener and a negative voltage for the -ve of the split-rail.
On taking mine apart I could see that there Is no D2, and it looks like it was never fitted, I have what looks like a factory fitted mod wire soldered from D4 to the -ve of C10. So effectively just joins together nets VDD and V_OSC on Dirk's schematic. I wonder if I have a later unit and they realised the devices didn’t draw enough VDD current to justify having two negative Zeners?
My plan now is to internally fit a small buck/boost split rail module, feed a supply the rails directly with properly regulated DC, drill out and fit an 1/4 output jack and a normal +9vdc Input. Hell, I might even buy some 1/2w LEDs to make the logo light up as all those filament bulbs in mine gave up long ago....
Danwarren
Post by Danwarren »
Have the pedal up and running now, I have salvaged an LED panel from a failed Audi number plate light to use in place of the 3x burned out filament bulbs
This is how I supplied power to it:
I have put my Clockwork Concubine Album on imgbb where the true extent of my bodging can be seen by all :lol:
It's quite a noisy pedal, IMO because the PCB ground point return routes of clocks/waveshapers share tracking with audio grounds, also741s have some poor audio parameters by modern standards...
Thanks again to Dirk et all for the massively helpful info in this thread :applause:
