Electra MPC Module Schematics  [schematic]
jsrfo
Post by jsrfo »
Does anyone have schematics or traces of the old Electra Guitar MPC modules? Just picked up a nice MPC guitar, and would like to attempt to make a module board, but would like to first see the thought process behind them, as the guitar uses one 150K pot to control one parameter on the effect. Pretty simple, I'd assume.
Any help would be appreciated. I'd even buy a broken or functional module to work from.
Nocentelli
Has thanked: 1152 times
Been thanked: 954 times
Post by Nocentelli »
Some superb (and possiblly trace-able) gutshots here:
http://www.rivercityamps.com/electra/modules.php
Axldeziak
Has thanked: 41 times
Been thanked: 38 times
Post by Axldeziak »
Looking through their forum it seems the phaser circuit was an original E-H Small Stone using CA3094 OTA.
jrod
Has thanked: 423 times
Been thanked: 46 times
Post by jrod »
Nocentelli wrote:Some superb (and possiblly trace-able) gutshots here:
The Overdrive looks to be basically the "Electra Distortion" schematic that's been floating around for years, but without the clipping diodes.
For the Dynamic Fuzz though the PCB trace side doesn't match up with the components.
Dr Tony Balls
Been thanked: 172 times
Post by Dr Tony Balls »
Dont have any schematics, per se, but I can chime in with some info. Awhile back a friend sent me two MPC modules in hopes that could get them working. The problem being that I dont have an MPC guitar to test them on. So I built a little pedal that could accept MPC cartridges for testing and use. Bought a 10 pin edge connector and just hooked it up outside a stompbox like so:
One cart was a distortion unit that I got working. The other was a phase shifter that I couldnt get to the bottom of so instead I set out to build a replacement circuit. You could print a PCB for this if you want, but I found that 0.15" pitch vero board was a close enough match for the edge connector. You just have to cut it to size and cut/file shoulders by the connector. Wound up putting a Magnavibe circuit on one:
jsrfo
Post by jsrfo »
I have just designed replacement PCB's for the Power Overdrive and the Dynamic Fuzz, and they work. So, now I need to figure out module boxes for these. Made one of each, and they work just fine. I intend to do a different overdrive as well, as I started out with those two original, simple circuits.
If anyone has suggestions on the module boxes, it would be appreciated.I thought about 3D printing.
jsrfo
Post by jsrfo »
So, I am in the process of obtaining 3D printed cases for module boards. Wish I knew how to embed a picture, but they're basically the same size as the originals, only dark grey.
I have my own overdrive, sold as a pedal called the El Mo, built into a card, and it works pretty nicely. Three trim pots to adjust the module level output, bass and treble. The guitar pot controls the gain, which also adds some level. I've found that setting the tones up allow for brightening up the neck pickup on my X330. I set the tone the way I like it on the bridge pickup with the tone pot at "5", and then I can roll of some highs on the bridge if I want, or add some highs on the neck pickup. Also, the ability to adjust the output level of the card provides the ability to set unity volume with the module turned on at any desired point on the module control pot, unlike the originals, which some actually had to be turned up fairly far for unity.
Anyway, I can currently build cards for the Electra Power Overdrive, my custom OD, and an Electra Distortion circuit with two germanium diodes at this point.
Looking if anyone has a true gut shot or schematic for the Dynamic Fuzz Module, or any of the other modules, I'd like to see if I could make boards for them as well.
pinkjimiphoton
my favorite amplifier: my own, a redesigned princeton
Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
gimme a like: http://facebook.com/pinkjimiphotonrocks
Has thanked: 358 times
Been thanked: 479 times
Post by pinkjimiphoton »
jsrfo wrote: 12 Jan 2020, 22:24 So, I am in the process of obtaining 3D printed cases for module boards. Wish I knew how to embed a picture, but they're basically the same size as the originals, only dark grey.
where ya getting the boxes printed? will you have the files for them? i gotta bud asked me if i could build him some, so curious
Slava Ukraini!
Has thanked: 4394 times
Been thanked: 2131 times
Nocentelli wrote: 10 Nov 2019, 16:56 Some superb (and possiblly trace-able) gutshots here:
This site is down, but I was able to retrieve the guts shots of the Distortion module from the waybackmachine... There are no diodes is this 'original' Electra Distortion!
pinkjimiphoton
that's the overdrive unit, the distortion uses a diode clipper, but is the same circuit
here's the phaser guts
phaser guts 1
phaser guts 1
phaser guts 2
phaser guts 2
here's more from the archive:
Electra MPC Module 1 - Phase Shifter.pdf
(868.78 KiB) Downloaded 306 times
Electra MPC Module 2 - Dynamic Fuzz.pdf
(668.06 KiB) Downloaded 308 times
Electra MPC Module 3 - Treble Bass Expander.pdf
(425.51 KiB) Downloaded 240 times
Electra MPC Module 4 - Tank Tone.pdf
(400.9 KiB) Downloaded 239 times
Electra MPC Module 5 - Power Overdrive.pdf
(543.21 KiB) Downloaded 275 times
Electra MPC Module 6 - Filter Follower.pdf
(952.53 KiB) Downloaded 250 times
Electra MPC Module 7 - Automatic Wah.pdf
(340.12 KiB) Downloaded 223 times
Electra MPC Module 8 - Tube Sound.pdf
(322.11 KiB) Downloaded 305 times
Electra MPC Module 9 - Octave Box.pdf
(293.67 KiB) Downloaded 239 times
Electra MPC Module 10 - Flanger.pdf
(740.08 KiB) Downloaded 244 times
Slava Ukraini!
pinkjimiphoton
more
Electra MPC Module 11 - Frog Nose.pdf
(315.03 KiB) Downloaded 227 times
Electra MPC Module 12 - Compressor.pdf
(859.47 KiB) Downloaded 234 times
electra distortion schem.jpg (15.7 KiB) Viewed 7350 times
this is most of what i've found so far. i'm building a couple of the cards for a friend, so hopefully these will help someone else.
Slava Ukraini!
pinkjimiphoton wrote: 11 Jul 2021, 13:05 that's the overdrive unit, the distortion uses a diode clipper, but is the same circuit
You are right: it is the Electra Overdrive module -- but as your list show there is never was an "Electra Distortion" module... or is it the Tube Sound module?
pinkjimiphoton
it appears what i call electra distortion module was the tube sound module. add diodes, and instant tube sound lol
i'll be working on some layouts for cards for a few things for my friend who has an electra guitar..
planning on building him the od and distortion, as well as maybe an envelope and phaser. i think i can squeeze a p45 into one of the perf boards he got.
they use 10 pin edge connectors. hopefully the stuff i posted earlier will be useful for someone down the road bro
Slava Ukraini!
jsrfo
Post by jsrfo »
I've build the "Electra Distortion" circuit schematic above into a module card. It's the one with the output pot.
Is there a back shot of the photo with the three transistors on it? Do you know what that one is?
jsrfo
Post by jsrfo »
This is my custom overdrive module for the MPC guitars. The circuit is my own, and I designed the printed circuit edge card. I also print my own module cases.
I also did an exact electrical copy of the MP5 Power Overdrive circuit, a Bass Fuzz, Boost, and that Electra Distortion circuit referenced as the Tube Sound above. I did a single chip chorus. It works, but I don't like it. Need to use the two chip version I suspect.
Currently working on a Univox Super Fuzz/Ibanez 59 Fuzz module.
pinkjimiphoton
hey bro, pm me some contact info? i gotta bud would probably buy some of these from you.
Slava Ukraini!
pinkjimiphoton
because i love you handsome dawgs n beetchez.... enjoy.... here's all the schematics for the electra plug in effect modules...
stolen off a facebook group.
i'd like to say personally FUCK MARK ZUCKERBERG. he's a reptilian weeny that sucks on octopus assholes.
this is the most worthwhile shit i ever found on his shitty fucking platform
MPC1_Phase_Shifter.pdf
electra mpc phaser
(2.46 MiB) Downloaded 317 times
MPC2_Dynamic_Fuzz.pdf
mpc dynamic fuzz
(2.44 MiB) Downloaded 341 times
MPC3_Treble_Bass.pdf
mpc treble bass
(2.31 MiB) Downloaded 295 times
MPC4_Tank_Tone.pdf
mpc tank tone
(2.55 MiB) Downloaded 307 times
MPC5_Power_Overdrive.pdf
mpc power overdrive
(2.22 MiB) Downloaded 334 times
MPC6_Filter_Follower.pdf
mpc filter follower
(1.81 MiB) Downloaded 273 times
MPC7_Auto_Wah.pdf
mpc autowah
(944.25 KiB) Downloaded 295 times
MPC8_Tube_Sound.pdf
mpc tube tone
(826.52 KiB) Downloaded 377 times
MPC9_Octave.pdf
mpc octave
(4.56 MiB) Downloaded 302 times
MPC10_Flanger.pdf
mpc flanger
(4.93 MiB) Downloaded 278 times
MPC11_Frog_Nose.pdf
mpc frognose amp
(1.74 MiB) Downloaded 279 times
EGC.pdf
egc info
(5.5 MiB) Downloaded 288 times
Update90-01011081a.pdf
some kinda related update
(1.8 MiB) Downloaded 279 times
Slava Ukraini!
CheapPedalCollector
Has thanked: 452 times
Been thanked: 147 times
Post by CheapPedalCollector »
Thanks bro!
andy-h-h
Has thanked: 23 times
Been thanked: 42 times
Post by andy-h-h »
pinkjimiphoton wrote: 13 Nov 2021, 23:58 because i love you handsome dawgs n beetchez.... enjoy.... here's all the schematics for the electra plug in effect modules...
So none of these actually match the Electra Distortion schematic that is commonly available - interesting... Has anyone actually seen a version of the Power Overdrive with the additional diodes or a Tube Sound matching the Distortion schem that we've all seen?
pinkjimiphoton
the guys on the electra facebook group have most of the modules, and there's a cat now reproducing them
Slava Ukraini!
