Maestro - MPF-1
sta.papad
Post by sta.papad »
:applause: Thank you very much for your help..! :D Can you explain how can i wire the (on off on) dpdt in the veroboard.?
Strangeamps
Been thanked: 8 times
Post by Strangeamps »
heres how to wire the dpdt
heres a schematic that uses the dpdt
Strangeamps
I cant seem to find the original diylc files for it, but heres the layout with some edits regarding the switch and pot connections
Visualdistortion
my favorite amplifier: Laney
Completed builds: Many...
Post by Visualdistortion »
The 2P2T switch it's:
Rotary Switch, 2x6, Pins
Lorlin rotary switch
2 pole 6 positions, (the total number of positions is selectable up to 6. Fix the number of positions using the ring)
or
Rotary Switch, 3x4, Pins
3 pole 4 positions, number of positions selectable, (the total number of positions is selectable up to 4. Fix the number of positions using the black ring)
Thanks a lot, I've buyed a 2x6 but something it's wrong.
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry ;)
zosotone
my favorite amplifier: Orange
Completed builds
Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Hornby Skewes Treble Booster
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver
Been thanked: 12 times
Post by zosotone »
Hi! I'm building the MPF. Can you put the numbers of the lugs on the pots? The wiper it's the second lug? Thank you :thumbsup
Greenmachine
Fender Blackface Deluxe Reverb
Completed builds
Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor
Has thanked: 96 times
Been thanked: 16 times
Post by Greenmachine »
zosotone wrote:Hi! I'm building the MPF. Can you put the numbers of the lugs on the pots? The wiper it's the second lug? Thank you :thumbsup
http://www.beavisaudio.com/techpages/Pots/
that site should answer a lot of your questions. welcome to stompbox building.
zosotone
Completed builds
Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver
Post by zosotone »
:slap: Thank you!
Greenmachine
Completed builds
Electra Distortion
Roger Mayer Octavia
MXR Phase 90
DOD FET Preamp
BYOC Analog Delay
Anderton Mini Amp
Keen Neovibe
Aquapuss Delay
DOD 280 Compressor
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
No problem. Watch your wallet, it'll get ugly.
zosotone
Completed builds
Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver
Post by zosotone »
I have clearly how to wire up the switches. The wipen it's the second lug, but the first and the third of the pots are indifferent? How must I wire up the dual pot? Must I link the lugs of the dual pot?
Nocentelli
Has thanked: 839 times
Been thanked: 785 times
Post by Nocentelli »
Link the wipers and connect them to the green wire marked "wipers" next to the frequency label: The other two green wires next to the frequency label must go separately to the two "lug3s" on the dual pot (furthest right when you hold the pot with the shaft pointing towards you and the lugs pointing down). The lug1s are unused.
zosotone
Completed builds
Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver
Post by zosotone »
Ok! And the other pot (height)? This picture it's correct?
Nocentelli
zosotone wrote:Ok! And the other pot (height)? This picture it's correct?
Yep, that looks fine.
zosotone
Completed builds
Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver
Post by zosotone »
Thank you men!
Visualdistortion
I made the pedal and I can't find where is my problem.
I've got a very big hiss with my signal, and the pots and switch control the amount of hiss :hmmm:
Some clues?
I wanna make it
French... sorry ;)
zosotone
Completed builds
Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver
Post by zosotone »
I don't now, I have not done still the pedal...
marshmellow
Has thanked: 16 times
Been thanked: 119 times
Post by marshmellow »
Visualdistortion wrote:I made the pedal and I can't find where is my problem.
Some clues?
Try a new 4007, take antistatic precautions when handling it.
jazzmaster
Post by jazzmaster »
Hi there,
first of thanks to Strangeamps for the quick vero layout!!
Im building this thing for a friend of mine, final assembly & test was today before i color the enclosures.
The build works fine, it seems that freq pot has kinda sweet spot at the heights, maybe this behave is normal because heights are more aggresive than low end to human ear. Near end of the range there is much going on ("sweetspot"), from ccw to that point it does not much. maybe a linear would be better, dodnt have dualpots here on spare so i cant try.
But i need to mention that im only tested it on a small speaker amp on low volume and with the loopstation as signal source (had to use audioprobe because i was getting no signal out of it ;)) also the loop didnt have the whole freqency spectrum of a guitar, i will inspect this tomorrow with a proper amp and a real guitar. will report back for that.
Also i went quickly over the service manual and i have here an updated version for the offboard wiring, which is correct to the schematic.
however height pot needs to be reversed if you mount it on top like on the regular effect. Why ? If you take a look at the original device you
can see pots are on the side, at each one if you think about how they are phisicaly mounted in respect to each other, you find they reversed. So you need to compensate this ;)
zosotone, this might be the porblem then...
greets,
jazzmaster
maestro mpf-1 offboard wiring
Visualdistortion
Thanks for your addition, i need to recheck mine
I wanna make it
French... sorry ;)
Strangeamps
Also to be noted, there's a schematic floating around and archived on Aron Nelson's site that has one component in the wrong spot, rendering the build to be non functional in overdrive mode. Go with the red and green schematic in this thread.
rockain
Post by rockain »
hello,
i like the circuit but stone deaf´s 5 different Q´s are verry versatile. can somebody tel me how i can make this too? resistor values etc.
thanks
