Maestro FSH-1 / Oberheim VCF / Tonepad Filter/Sample/Hold [schematic]
- chicago_mike
So somehow i used a 5 ohm resistor instead of a 1 meg in one area.
I'm rewiring both my FSH's with color coded ribbon wire. ...hopefully to keep the rats nest look down.
So, I think my pedals should be good now. Found some 2N5457's locally too.
Skyline FX 2013
- grrrunge
Fingers crossed It's an awesome pedal!chicago_mike wrote:So somehow i used a 5 ohm resistor instead of a 1 meg in one area.
- chicago_mike
thanks!!
I put some "mojo" parts in my juggernaut clone just now and I think I'm ready to finish my fsh's.
I'd atempt at putting "mojo" parts in my fsh..but I just know my house would explode...
Skyline FX 2013
- chicago_mike
- chicago_mike
Haven't seen one.
Skyline FX 2013
- grrrunge
HBO made one. It's here: http://www.sabrotone.com/?p=488agoldoor wrote:When is someone going to dare creating a vero layout for this pup? THAT would be cool.... *hint hint*
- chicago_mike
who the hell is crazy enough to vero board this thing??!!!??
People have enough trouble with the pcb version as is!
Skyline FX 2013
- chicago_mike
hey Grrunge...
How did you hook up your grounds?
Also..I am getting it to almost work. I get I think the down sweep? The thinner sounding sweep. The other direction has just a low bass output..no sweep.
And the sample/hold..I need to readjust the trimmers...It WAS working before..
The only parts swap I have really done was the .15uf caps. I don;t have those, but I have.1 and .22 .
And I'm going between mpf102 and 2N5457's.
Skyline FX 2013
- grrrunge
input- and output grounds directly to chassis, and supply ground to input sleeve lug.chicago_mike wrote:hey Grrunge...
Try turning the range knob, as i wrote a few posts back:chicago_mike wrote:Also..I am getting it to almost work. I get I think the down sweep? The thinner sounding sweep. The other direction has just a low bass output..no sweep.
grrrunge wrote:...The range setting that makes awesome swooshing sounds on the up setting, makes almost no sound on the down setting and vice versa.
- chicago_mike
Yeah, I move that range pot all over. I swapped it out and will try again. =)
I am using an active bass, But I have yet to measure the pp voltage output....but, I dont think it should matter???
Anyhoo, I'll get them to go.
Skyline FX 2013
- chicago_mike
Oh and speaking of grounds...
I got these copper ..forgot that they are called..
But they're like a real skinny pcb. I can use those as a star ground.
Skyline FX 2013
- grrrunge
Star ground? How many ground wires do you have?chicago_mike wrote:Oh and speaking of grounds...
- chicago_mike
9 volt ground
input and output ground
board ground
led ground
I don't want to create a ground loop.
I wonder if my 13700 is bad..since I'm just not getting sweep in one of the positions. All other wiring is good and tidy. All parts are correct except the .15's which I used .22 and .1..I don;t have .15's small enough.
board ground
led ground
Skyline FX 2013
- grrrunge
If it sweeps one way but not the other, check the up/down switch wiring and the surrounding components.
It doesn't sound like a bad OTA to me...
- chicago_mike
coolness. I double triple dipple check.
Skyline FX 2013
has anybody else had problems with the gain of the circuit? mine is very weak. are there any ideas to improve the gain or do i have to add a booster in front. Also what would i have to tweak to make the LFO go faster? I really can't find any use for the very slow sample&hold..
- chicago_mike
for gain I think you could try increasing or decreasing the input and output cap values.
For more S&H Speed....hmm..thats a puzzler.
Skyline FX 2013
