SolaSound - Tonebender 1971  [schematic]
Fender3D
Has thanked: 111 times
Been thanked: 139 times
Post by Fender3D »
This arrived for repairing.
It's a late '60 Tone Bender by Sola Sound.
I redraw the schematic with actual values and wires color... :thumbsup
Fuzz control works reversed.
Transistors and diode are unsigned.
Enjoy
The attachment SolaSoundTB1sm.JPG is no longer available
Schematic
Has thanked: 1111 times
Been thanked: 955 times
cool bro, thanks for sharing
what's the actual board dimensions?
Fender3D
Post by Fender3D »
76.9 X 75.9 mm
armdnrdy1
Been thanked: 68 times
Post by armdnrdy1 »
Why couldn't you have received a Colorsound flanger for repair? :slap:
I'm working on the board routing and....I could use a few trace side shots!
Fender3D
Post by Fender3D »
more pics...
kymar
Been thanked: 13 times
Post by kymar »
Thanks for nice pic!
Could you measure voltages Qc1, Qc2, Qc3, please?
kymar wrote:Thanks for nice pic!
this!
Electric Warrior
Has thanked: 23 times
Been thanked: 98 times
Post by Electric Warrior »
Can you read the pot codes? Probably early '72.
Fender3D
Post by Fender3D »
Q1:
C = -5.024 V
B = -1.300 V
E = -1.232 V
Q2:
C = -5.024 V
B = -1.232 V
E = -1.140 V
Q3:
C = -2.540 V
B = -0.071 V
E = 0 V
Electric Warrior wrote:Can you read the pot codes? Probably early '72.
On pot you find:
Radiohm 100K A D-74
Fender3D
Post by Fender3D »
I forgot
Battery = 9.70V
Fender3D
Post by Fender3D »
Updated schematic:
added transistors voltages, moved battery switch to output jack
Sola Sound Tone Bender.pdf
Electric Warrior
Fender3D wrote:
On pot you find:
Radiohm 100K A D-74
Thank you! That would be D-71. By 1974 the pot codes were stamped into the top surface of the pots.
Fender3D
Post by Fender3D »
lol
1.2 corrected electros polarity
(37.89 KiB) Downloaded 318 times
jalmonsalmon
Has thanked: 82 times
Been thanked: 26 times
Post by jalmonsalmon »
32uF is a funky value but I assume since it is just going from -VCC to ground, a 33uF will be okay or whatever works LOL
thanks!
Electric Warrior
Sure. Sola Sound mostly used 22µF or 25µF as a power filter cap for these in that particular era. They started out with 50µF, but whatever works..
Bret608
Post by Bret608 »
Cool unit! Glad you were able to share the voltages. Q3 was definitely what I would have expected. Q1 and Q2 are slightly higher than I thought they would be on the collector. Then again it's still roughly half supply voltage.
I know these "top hat"-style transistors are normally not marked. Has anyone ever seen marked versions of them anywhere?
Electric Warrior
I've seen a couple of marked ones in Tone Benders, but never the same type twice. :mrgreen:
Bret608
Post by Bret608 »
That's what I love about this circuit, nice and forgiving of different transistor types.
EW, I'm actually working on a build right now using your MkIII layout. The one with the 680k/150k bias string...I think I've got just the right gains/leakages in my stash of no-name germaniums. We'll see I guess!
Electric Warrior
Good luck! Trying different types in this circuit sure pays off! Q3 is quite sensitive to leakage. Great for shaping the tone. And I found that transistors wired up as a diode sound different from the germanium diodes I have. Worth a try!
I don't think leakage is that bad in mk3. I kind of like it if it leaks. I often fake leakage setting resistor or resistor in series with pot between C and B
