Dynacord - Federhall 1960 [schematic]
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
please does someone have schematic for this spring reverb...?
https://reverb.com/ca/item/13111710-dyn ... 960-s-rare
- borislavgajic
- Opamp Operator
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
For easy reading:vintagekiki wrote: ↑02 Jul 2020, 21:35 http://www.jabse.com/L0RZTkFDT1JEL0F1ZGlvL01hZ2ljIEhT
http://www.peel.dk/Dynacord/Magic.html
- bow_and_error
I have a similar tank, and this is one of only 2 circuits I've seen that uses a high input/output impedance tank with grounded input & output connectors. The other is the Nonlinear Circuits Big Room Eurorack module (based on Polyfusion VC Reverb). The high impedance of these tanks requires a lot of drive current, so they usually have higher voltage PSUs than more common lower-impedance tanks. So keep that in mind if you need to find a replacement PSU.
Here is the decoded tank information:
Dynacord Spring Reverb Tank - #4FB2A1C
Digit - Specification
1st - Reverb Type - (4) - Type 4
2nd - Input Impedance/DC Resistance - (F) - 1,475/200 Ohms
3rd - Output Impedance/DC Resistance - (B) - 2,250 Ohms/200 Ohms
4th - Decay - (2) - Medium (1.75 to 3.0 s)
5th - Connectors - (A) - Input Grounded/Output Grounded
6th - Locking Devices - (1) - No Lock
7th - Mounting Plane - (C) - Vertical, Connectors Up
You can still find replacement tanks if needed.
