Page 4 of 22
Re: Univox - Superfuzz
PostPosted: 17 Apr 2009, 08:59
by ShortScaleMike
haha, it's Mike, but glad you have it working anyway, always a satisfying feeling!
From looking at other Octave Fuzzes like the Foxx Tone Machine, I would suspect that it is the Q3 emitter path 10uF 470 junction you want to break to cut the Octave effect.
PostPosted: 17 Apr 2009, 11:16
by Solidhex
Hmm
Wonder if sticking a pot in there and putting in some series resistance would let you blend in the octave. The usual 10k octave balancing trimpot does it a little...
--Brad
PostPosted: 12 May 2009, 06:44
by salocin
Thanks for the layout Mike. Just got mine finished and it's great!
Here's how it came out:
Unfortunately it's for someone else so will be building another for myself straight away.
PostPosted: 13 May 2009, 09:18
by ShortScaleMike
Wicked, always great to see when people use the layout. That's a great looking pedal.
PostPosted: 18 May 2009, 09:18
by metulmykul
Finally got one of these together on the weekend.
Many thanks to ShortScaleMike for his layout and all who had input on it.
I can say that this build is a whole lot better to my ears than the Leeds Fuzz kit that i built. Both use 2SC828s but this has an unadulterated rawness that leaves the BYOC somewhat sterile in comparison.
How a fuzz should be in my opinion :twisted:
PostPosted: 18 May 2009, 15:53
by ShortScaleMike
Nice to hear, good stuff!
PostPosted: 24 May 2009, 10:23
by theblackman
this is a great sounding fuzz, i was bashing out some riffage through my octane 3 yesterday which is the same circuit AFAIK
PostPosted: 25 May 2009, 22:09
by Nikifena
I make this pedal maybe before more than 5 years.
Here is it:
It's good pedal, but right now I preffer to use a few schottky diodes instead normal 4148 diodes.
PostPosted: 26 May 2009, 01:56
by MJS11
I am new to this and was wondering if anyone can help with a wiring diagram for the layout posted here?
PostPosted: 26 May 2009, 20:50
by modman
This one contains wiring information, else you should check the schematic on the first page
viewtopic.php?p=37093#p37093
PostPosted: 27 May 2009, 07:40
by Caillan
I have tried to add a DC jack to plug into an adaptor, now my fuzz keeps dieing! I have traced the problem to something going wrong in the pots, so I replace them and they work for a while then something happens and they die again... any ideas as to what I might have done wrong??? I'm completely stumped!!
PostPosted: 27 May 2009, 08:55
by Solidhex
Yo
You most likely wired it wrong...
Its interesting the amount of components for the Superfuzz. Lots of transistors for a fuzz. I think the fuzz and octave seem to have a richer, deeper tone to it than most diode clipping octave fuzzes. Is that second transistor really needed at all. The buffer after the first stage?
--Brad
PostPosted: 27 May 2009, 22:22
by salocin
Caillan wrote:I have tried to add a DC jack to plug into an adaptor, now my fuzz keeps dieing! I have traced the problem to something going wrong in the pots, so I replace them and they work for a while then something happens and they die again... any ideas as to what I might have done wrong??? I'm completely stumped!!
I had a similar problem. It would work for a minute or two and then slowly die over about 30-40seconds. Turned out I had accidentally cut a track which, from memory, was just after a cap around q2.
I also had problems with a bad solder joint on one of the pots so check them too (even if they look fine!)
PostPosted: 29 May 2009, 08:52
by Caillan
Yeah, I had built a working circuit from an etched PCB, but of course I felt the need to add a few little modifications (DC jack, power starve pot...) and (typically) now I've ruined everything!! I am pretty sure its a power source issue, my DC jack is wired as such..
Please let me know if I have done this wrong, it's the first time I have tried adding a DC jack so frankly I'm just taking stabs in the dark!
PostPosted: 29 May 2009, 09:20
by ShortScaleMike
switch the 9v battery and 9v circuit connections and you're golden.
PostPosted: 29 May 2009, 10:43
by Caillan
Argh, still nothing.. I did a bit of probing with my handy ol multimeter and found that there is absolutely no current running through the pots, ideas??
PostPosted: 29 May 2009, 21:00
by devastator
Anyone tried to change the tone switch to a potentiometer like zvex did on his Octane 3 ? That can allow more sound possibilities.
I saw a lot of fuzz pedals use this tonestack.
PostPosted: 29 May 2009, 21:26
by ShortScaleMike
Don't measure current. Measure voltage and start with the places you're expecting to see +9V, ground, and bias (on the transistors).
Debugging can be frustrating but it is actually very simple. Check everything methodically and you will find the problem. Presume nothing. Verify everything.
PostPosted: 10 Jun 2009, 13:33
by skumberg
ShortScaleMike wrote:Thanks for teh corrections Graeme, this is now a verfied layout:
Hello Mike, I've been looking for a SF layout and was thinking about building yours, after looking att schematics shouldn't there be a 100k to ground at the output?
Would an external 10k pot be useful to balance Q4 and Q5 or is that a set and forget thing? I see you have used the schematic whitout the 10k trim found on some schematics so maybe somebody else knows?
Nicklas
PostPosted: 12 Jun 2009, 11:25
by ShortScaleMike
Obviously we are looking at different schematics. My layout is accurate for the one I used.
There were multiple variations of this thing by various different companies.
