Ross - Chorus
Greetings to everyone, here's some porn of an old (and beat up) ROSS Chorus pedal owned by a friend who wanted to have true bypass on it. Surprisingly, he didn't want to change that dreadful current jack (which I personally hate). I love these enclosures though, the pedalenclosures boxes are like these just without the sunken knobs (good protection).
Some pictures are from before and after the true bypass operation, the original switch was going flimsy.
It sounds really good, and is very simple, I started tracing it until I realized it is a direct copy of the BOSS CE-2, so I put the schematic up for reference. The obvious difference is in the switching scheme, if you didn't power it, it wouldn't work, but it lacks the flip-flop circuitry, looking at the schematic, the switch was between R49 (1M) and ground, and that's how it operated.
I know there's nothing new here, but still, I anyone enjoys it, that's great.
- Dirk_Hendrik
- moltenmetalburn
I like the washers. always did.
Actually I suggested that to my friend Dirk, but the guy insists in having it. I like it in some pedals, though, I don't know why.
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
Dirk_Hendrik wrote:Please!!
Dump the ugly white washer!
- lolbou
I'm sure there's a "anti-white washers" group on facebook... And I would be a member in it if only I were registered on facebook...
Did you compare it with a boss CE-2 regarding sound?
And are the values exactly the same as on the schematic?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
No, I didn't compare it with a CE-2, and as far as I went with the tracing, the values were identical, say, half of the schematic
I know I am making a bold assumption there, but it might be justified.
- The Rotagilla
No, you're right. I compared the two schematics side by side and there's two, maybe three parts that are either different or omitted in the Ross. CE-2 sound without the CE-2 price.Fuzzer wrote:No, I didn't compare it with a CE-2, and as far as I went with the tracing, the values were identical, say, half of the schematic. I know I am making a bold assumption there, but it might be justified.
Oh, ¿do you have the ROSS schematic?, could you post it, please? An thanks for the confirmation.
- The Rotagilla
Ross Chorus SchematicFuzzer wrote:Oh, ¿do you have the ROSS schematic?, could you post it, please? An thanks for the confirmation.
Reason: changed link
- borislavgajic
- Opamp Operator
Yes , and now only if we could get trace side of PCB....?
but, why do you need it?; ; what for? I can photograph it, no problem, will just have to wait some time.
- The Rotagilla
I agree with Fuzzer on this one. Pick your favorite Boss CE-2 layout and make the changes.Fuzzer wrote:but, why do you need it?; ; what for? I can photograph it, no problem, will just have to wait some time.
- analogguru
This file can only be downloaded 10 times.....Rotagilla wrote:Ross Chorus schematic
- borislavgajic
- Opamp Operator
so is it ok if I attach it now, and here?
- Ross_Chorus_a_c.gif (70.96 KiB) Viewed 3608 times
- Ross_Chorus_b_c.gif (68.06 KiB) Viewed 3605 times
Shiiite, I'm sorry modman, I attached it and remembered the reason why maybe Rotagilla didn't post it, so I took it away, but forgot to delete the post. Don't make fun of me you $%& (And I can't delete it now, if you can, please do).
Anyway, Mr. Borislavgajic has attached it now.
- LaceSensor
Could you detail how you did the true bypass and cam this be millennium bypasses? I have one in an all blue box, is it rare? The switch is a bit flaky, it's all original. Thanks
Ei, I'm new in the forum.Well, I found this post and it interests me because I have this board from a pedal that was given to him to do a tattoo pedal.He removed the inside, and guess what, it's a Ross Chorus.Well, there are some components missing from the board, and also, have no clue where the input/output/ground connectors are.Anyone can send me a layout of the components?ThanksFuzzer wrote:Shiiite, I'm sorry modman, I attached it and remembered the reason why maybe Rotagilla didn't post it, so I took it away, but forgot to delete the post. Don't make fun of me you $%& (And I can't delete it now, if you can, please do).
Nuno
